Polly Posted February 13, 2009 Posted February 13, 2009 Would anybody please show me how to do the page setup file to use with sheet set manager? I'm using ACAD 2008 with Windows XP. I have tried to do it with whatever Help guide me, but I'm still confused, and when I browse to the file I've created it gave me the message that there is no named paperspace in that file. Please help:( Thank you so much. Quote
JONTHEPOPE Posted February 13, 2009 Posted February 13, 2009 http://www.jtbworld.com/lisp.htm RKENT SAYS GO HERE SAVE PAGESETUP LSP IN NOTE PAD SAVE AS .LSP THEN DRAG AND DROP INTO DRAWING SCREEN Quote
Polly Posted February 13, 2009 Author Posted February 13, 2009 Thank you and I will try to see if it works. Quote
JONTHEPOPE Posted February 13, 2009 Posted February 13, 2009 I JUST TRIED THIS AND I COULD SEEM TO GET IT TO WORK NOT SURE WHAT IT DOES I DID SEE SOME VB CODE IN THE COMMENTS WILL LOOK INTO IT... Quote
JONTHEPOPE Posted February 13, 2009 Posted February 13, 2009 I FOUND THIS ON AUTODESK WEB SITE You have to have a template file with the pagesetup(s) defined. From that template in the Import dialog, select the pagesetups you want to import. Select one to set Current. Leo wrote in message news:5742108@discussion.autodesk.com... page import doesn't bring in anything, it says that it does but doesn't! Quote
JONTHEPOPE Posted February 16, 2009 Posted February 16, 2009 Open drawing and go in to page set up then set up as you like then save as template file (.tmp) . now you can import your page set up in the page set-up manager . Quote
