CONVERT DGN TO DWG OR PDF... etc...
I Don't Have Microstation, Any Other Way To At List View The File...?
Thank You,
Anj
I'm not sure if regular AutoCAD has the capabilities, but Civil 3d and/or Map both support xrefing of v8 dgn's.
I can not install other software by policy, but i have illustrator, photoshop, dreamweaver, flash, autodesk dwf viewer, indesign and AutoCad-08!
thank you for your help,
anj
intellicad or rhinoceros open DGN files
both have a free beta/trail, but if you are not having admin rights and can't install i understand, but on a laptop?
I would just contact the person who sent you the file and ask them to either convert it to dwg or send you a pdf so you can view it.
Or tell your IT guy that you need to install that free viewer that uddfl posted.
Hi fedora
You can insert the DGN file in side the empty AutoCAD file
  • 1 month later...
DGNDirrect from the open design alliance lets many of the intellicads open this file format... that is another option
  • 2 months later...
Rasterex's RxView or RxHighlight view DGN. RxHighlight allows for file conversion also see www.rasterex.com
