Good afternoon,
we have started using data extraction tool EXTRDATA which has proven a great time saver, however, the table it outputs doesn't properly sort data, which is very frustrating. This needs to be sorted properly upon each extraction.
Currently data sorts in this manner:
A1
A10
A2
Desired sorting is this:
A1
A2
A10
Picture:
Users are placing a specific block into a drawing, which prompts them to type in attribute BOD, which is it's name that gets extracted along with it's x and y coordinates of insertion point. Due to the format of the name being a letter + number, autocad doesn't sort this properly. Exporting to excell, sorting it there and returning it back to AutoCAD is undesirable. LISP is not an option, because we are using AutoCAD LT for most of our workstations.
I tried searching for a diesel expression to create a different attribute, which the extrdata would sort properly, but no luck so far.
There might also be a way through generating a new data format, or using an existing one in a clever way. I wasn't able to find it though.
Could anybody help us achieve this?
Thank you and have a nice day.
Edited by Janouren
More accurate title
  • Janouren changed the title to How to sort data in data extraction table alphanumerically?
The only way to end up with a table sorted the way you want is to either sort all the data 1st before making table or read a table and totally recreate it in a sorted order. So yes need a list, dont panic lists can be huge in thousands of items.
