phjlc Posted April 28, 2022 Posted April 28, 2022 Good day, Just want to ask what would be the simplest way to do create this dynamic block with autolisp, I've created this manually, but another modification is needed to be applied and the data for new said modification is in Excel, I could, perhaps redo it again........ file is provided with a sample of the block, Im also open to suggestion on a way easier method rather than dynamic block, but I would like to learn a way to automate this kind of block. SAMPLE.dwg Quote
mhupp Posted April 28, 2022 Posted April 28, 2022 Look into dcl for another option. we use that here when starting a new project and need to fill out the title block. pops up a little menu that we manually fill each item then it populates all the title blocks in the drawing. https://autolisp-exchange.com/Tutorials/MyDialogs.htm#MyEditBoxes Quote
BIGAL Posted April 28, 2022 Posted April 28, 2022 You can as part of insert a dynamic block any dynamic block get its visibility state and use a dcl to choose. The dcl is based around lee-mac get dynamicblock properties.lsp and Populating a dcl. Whilst my Multi radio buttons may work the nearly 30 as radio buttons is pushing the limits, using a list box would be easier as you can scroll long lists. This is a window dynamic block. If you want to go this way just post. Quote
phjlc Posted May 6, 2022 Author Posted May 6, 2022 (edited) Hello, Sorry for not responding for a long time, Thankyou for your suggestion, but I think its kind of complex to code this dcl and I would like to look into it further and learn in the future but for now, I have resolve the problem. the only thing is I cant seem to figure out is to create a parameter and dont have to manually select it in the code provided below (setq ;start of point setting bpt-ld1 '(2.0 5.0 0.0) bpt-ld2 '(4.0 5.0 0.0) bpt-ld3 '(3.0 5.5 0.0) bpt-d1-b1 '(3.0 10.0 0.0) bpt-d1-b2 '(12.5 2.0 0.0) ) ;end of point setting (command "BPARAMETER" "L" bpt-ld1 bpt-ld2 bpt-ld3 "2") ;-creating Linear Parameter ;(setq ent-parameter (entlast)) ;-assigning the parameter (command "BACTIONTOOL" "ST" (ENTSEL) bpt-ld2 bpt-d1-b1 bpt-d1-b2 ssgb allpara "") ;adding action to parameter Ill try to explain as clear as I can this said code is in block editor, as you can identify in this example, instead of inputting ent-parameter string, I instead use (ENTSEL), Ive even tried ssget "w" (windowed said parameter) that yield 3 items including the grip and tried all of the said ent with (ssname 0/1/2 ssgetlist) But still yielded "Select Parameter" If anyone know how I can remove the entsel that would be nice, but regardless I resolve the problem Thankyou for the response. Edited May 6, 2022 by phjlc correcting grammar Quote
