Possible to grab transparent command return result in variable?
MJLM
Hi,
I have made my fast selection routine that collects members of a network as a chain and returning as a selection set . I would like to get the returning ss running it as transparent, that is while already being inside an other routine on an active ssget prompt, type 'my_fast_selection_commad and get the ss coming from the transparent command. From what I have tried, it seems it is not possible?
Can a transparent command return anything apart from nil?
So if I am reading this correctly you ant something like:
(not in code tags since this isn't really code, just the idea)
(defun c:testlisp ( / )
 [Do some setp stuff]
 (setq MySS (ssget... get selection se)
    [But can type in (my_fast_selection_command) in setq MySS (my_fast_selection_command)]
 [do more stuff]
I have something that will do this with an entsel, rather than a selection set I think - it might be able to be modified using SS
I think using a while loop and an initget night be working something like
(setq endloop "No")
(initget my_fast_selection_command)
(whle (= "No" endloop)
  (if getsting "my_fast_selection_command (progn (setq MySS (my_fast_selection_command))(setq endloop "Yes")))
  (setq MySS (ssget...))
);end while
Somthing like that if I remember what I did correctly - gives you smething to thinkaboutfor now anyway.
Maybe this example of a erase shortcut note the transparent 'ZZZ must use single quote for transparent.
(defun c:zzz () (ssget "X" '((0 . "LINE"))))
Erase 'zzz Enter
Erase 'zzz Enter
That's new to me! Thanks
