hi friends
i search the entire web with no success
I'm looking for lisp that will extract specific block tag value as field that i could use it in my program.
THX for the help
The problem is that objid is for that attribute in just 1 block, the next block attribute will have a different objid value. If that is ok say select block get objid and make the correct string to use in say mtext.
You need to use something like this, where att is the  attribute
(strcat "%<\\AcObjProp Object(%<\\_ObjId "
(vlax-invoke-method (vla-get-Utility  (vla-get-activedocument (vlax-get-acad-object))) 'GetObjectIdString att :vlax-false)
">%).Textstring>%"
 ) lst ))
thx bigal but its not working
i have this lisp from lee mac that give me great start but i couldnt to change it to work as a field
Quote
(defun LM:GetAttributeValue ( block tag )
    (vl-some
        (function
            (lambda ( attrib )
                (if (eq tag (vla-get-Tagstring attrib))
                    (vla-get-TextString attrib)
        (vlax-invoke block 'GetAttributes)
(defun c:test1 ( / ent )
    (if (setq ent (car (entsel "\nSelect Attributed Block: ")))
        (setq space_ex (LM:GetAttributeValue (vlax-ename->vla-object ent) (strcase "space")))
Pretty sure its case sensitive. so number wouldn't work but NUMBER will same with SPACE.  NM see their using strcase to uppercase everything
Also its a good idea to keep the authors notes/headers.
Are you wanting the object id (2419762663504) or the value (20)?
hi mhupp i want the number but as a field.
In case anyone changes it then it will affect other block.
THX To Bigal
i found old post of him and solve the problem
