Hi All,
can anybody convert this lisp to sq.ft. now the area i am getting area in sq m.. looking for polyline area to be placed in sq ft when it selected. thank u.
PLA.LSP
4 hours ago, rose sr said:
Hi All,
; Select closed polyline and place mtext with the room name and Area in ft2
; How to use:
; 	1. select polyline
;	2. type in room name
;		Note: the getstring function does not allow spaces, so use a _ underscore to seperate words
;	3  select insert point
;	4  Something similar to this will be placed with MTEXT
;		room_name
;		Area: 111.11 ft2
;	5  MTEXT will be placed with no wrap, to current settings
; Created
; 11-June-2003	YZ
;	This code was taken from an internet web site. the original author was 'Jos van Doorn'.
;	Among other things, I have modified the program to use MTEXT.
(defun drtxt_ft (/ rn tx ls vl lt ht lb hb nr pt)
  (setq tx (strcat "Area: "
	   (rtos (* (/ (getvar "area") 1000000) 10.7639) 2 2)
	   " ft\U+00B2"
	   rn (getstring "\nRoom Name: ")
  (setq ls (list (cons 1 tx))
  	vl (textbox ls)
  	vl (cadr vl)
  	lt (car vl)
  	ht (cadr vl)
  	vl (grread T)
  	nr (car vl)
  	pt (cadr vl)
  (princ "\nInsert Point: ")
  (while (/= nr 3)
    (command "redraw")
    (grdraw pt (setq pt (polar pt 0 lt)) 7)
    (grdraw pt (setq pt (polar pt (* pi 0.5) ht)) 7)
    (grdraw pt (setq pt (polar pt pi lt)) 7)
    (grdraw pt (polar pt (* pi 1.5) ht) 7)
    (setq vl (grread T)
	  nr (car vl)
	  pt (cadr vl)
    ) ;end while function
  (command "-mtext" pt "w" 0 rn tx "")
  (redraw)
) ; end drtxt function
(defun c:plaft ( / et)
  (setvar "cmdecho" 0)
  (while (setq et
	   (car
    	     (entsel "\nSelect polyline: ")
  	   ) ;end car function
	 ) ;end setq function
  (command "area" "o" et)
  (drtxt_ft)
  ) ; wnd while funtion
(setvar "cmdecho" 1)
) ; end c:plaft function
like this?
Edited by exceed
