I will be using this for '06.
I want to put this command at start up but I'm getting a message
"Autocad Menu Utilities Loaded. *Cancel*"
My code is something like this:
(defun S::STARTUP ()
 (command "CleanscreenON")
(princ))
Anyone there willing to shed light on this.
Try adding this in your acaddoc.lsp file
(command "cleanscreenon")
...worked when I tried it
As quoted from ACAD Help:
The startup LISP files (acad.lsp, acaddoc.lsp, and MNL) are all loaded into memory before the drawing is completely initialized. Typically, this does not pose a problem, unless you want to use the command function, which is not guaranteed to work until after a drawing is initialized.
