rlassoc10 Posted June 7, 2022 Posted June 7, 2022 beam.lspbeambeam.lsp.lspbeam.lsp I have a dialog box with several inputs. One of the has a key=top_cant. When something is put in this box I need an action tile to run RTD that is in the beam.lsp file that is attached. I haven't done any action tile programing in 25 years. You can see what I have done so far in the attachment, but it doesn't work. I haven't found anything that explains action tiles to really help me out. Any help would be appreciated. Quote
Steven P Posted June 7, 2022 Posted June 7, 2022 Not sure if this helps but I for some reason I always put the (done_dialog) after any other actions for that action. I also put a 0 or 1 at the end - again can't remember why I do that (1 for accept, 0 for cancel) for example you might do: (action_tile "cancel" "(setq userclick1 nil)(done_dialog 0)" Not sure if that helps? Quote
mhupp Posted June 7, 2022 Posted June 7, 2022 This is incomplete I need the dcl as well. where is "a" defined? Is userclick1 variable used in the dcl also? Its a good idea to combine the dcl and lisp file. Your also storing system variables to recall but not changing them and then resetting them before you exit. This is a nice little trick to set multiple variables (setq vars '(cmdecho blipmode osmode) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars '(0 2 3)) ;set new values ;if you want to set them all the same value ;(mapcar '(lambda (x) (setvar x 0)) vars) ... ;lisp (mapcar 'setvar vars vals) ;set old values before exit of lisp Quote
BIGAL Posted June 7, 2022 Posted June 7, 2022 This may be helpful I did not test, http://www.theswamp.org/index.php?topic=57626.0 Quote
