neekcotrack Posted February 16, 2009 Posted February 16, 2009 I have a lisp and I have not been at this for a while so I can't remember how to make the layer E-Wire to have the color 11. instead of white. Thanks appriate any help given. (vl-load-com) (defun C:tics (/ ActiveDocObj Ent EntName EntObj InsParam InsPoint Temp TextAngle TextHeight TextString TextWidth TextStyle TextLayer ) (setq TextHeight 8.0 TextString "" TextWidth 0.31 TextStyle "Tics" TextLayer "E-Wire" ) (if (not (tblsearch "STYLE" TextStyle)) (entmake (list (cons 0 "STYLE") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbTextStyleTableRecord") (cons 2 TextLayer) (cons 70 0) (cons 40 TextHeight) (cons 41 1.0) (cons 50 0.0) (cons 71 0) (cons 42 TextHeight) (cons 3 "romans.shx") (cons 4 "") ) ) ) (repeat (progn (initget 7) (getint "\nNumber of tics: ")) (setq TextString (strcat TextString "/")) ) (setq ActiveDocObj (vla-get-activedocument (vlax-get-acad-object))) (vla-EndUndoMark ActiveDocObj) (while (and (setq Ent (entsel))) (setq EntName (car Ent)) (if (and (wcmatch (vla-get-ObjectName (setq EntObj (vlax-ename->vla-object EntName)) ) "AcDbLine,AcDbPolyline,AcDbArc,AcDbCircle" ) (setq InsPoint (vlax-curve-getClosestPointTo EntObj (cadr Ent))) (setq InsParam (vlax-curve-getParamAtPoint EntObj InsPoint)) ) (progn (setq TextAngle ((lambda (d) (if (zerop (cadr d)) (/ pi 2) (atan (apply '/ d)) ) ) (cdr (reverse (vlax-curve-getFirstDeriv EntObj InsParam) ) ) ) ) (vla-startundomark ActiveDocObj) (entmake (list (cons 0 "TEXT") (cons 7 TextStyle) (cons 8 TextLayer) (cons 1 TextString) (cons 40 TextHeight) (cons 10 InsPoint) (cons 11 InsPoint) (cons 41 TextWidth) (cons 50 TextAngle) (cons 72 1) (cons 73 2) ) ) (vla-endundomark ActiveDocObj) ) ) ) (princ) ) Quote
fixo Posted February 16, 2009 Posted February 16, 2009 Something like this? (vl-load-com) (defun C:tics (/ ActiveDocObj Ent EntName EntObj InsParam InsPoint Temp TextAngle TextHeight TextString TextWidth TextStyle TextLayer ) (setq TextHeight 8.0 TextString "" TextWidth 0.31 TextStyle "Tics" TextLayer "E-Wire" ) (if (not (tblsearch "STYLE" TextStyle)) (entmake (list (cons 0 "STYLE") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbTextStyleTableRecord") (cons 2 [color=red]TextStyle[/color]) (cons 70 0) (cons 40 TextHeight) (cons 41 1.0) (cons 50 0.0) (cons 71 0) (cons 42 TextHeight) (cons 3 "romans.shx") (cons 4 "") ) ) ) (repeat (progn (initget 7) (getint "\nNumber of tics: ")) (setq TextString (strcat TextString "/")) ) (setq ActiveDocObj (vla-get-activedocument (vlax-get-acad-object))) (vla-EndUndoMark ActiveDocObj) (while (and (setq Ent (entsel))) (setq EntName (car Ent)) (if (and (wcmatch (vla-get-ObjectName (setq EntObj (vlax-ename->vla-object EntName)) ) "AcDbLine,AcDbPolyline,AcDbArc,AcDbCircle" ) (setq InsPoint (vlax-curve-getClosestPointTo EntObj (cadr Ent))) (setq InsParam (vlax-curve-getParamAtPoint EntObj InsPoint)) ) (progn (setq TextAngle ((lambda (d) (if (zerop (cadr d)) (/ pi 2) (atan (apply '/ d)) ) ) (cdr (reverse (vlax-curve-getFirstDeriv EntObj InsParam) ) ) ) ) (vla-startundomark ActiveDocObj) ;;;(entmake (list (cons 0 "TEXT") ;;;(cons 7 TextStyle) ;;;(cons 8 TextLayer) ;;;(cons 1 TextString) ;;;(cons 40 TextHeight) ;;;(cons 10 InsPoint) ;;;(cons 11 InsPoint) ;;;(cons 41 TextWidth) ;;;(cons 50 TextAngle) ;;;(cons 72 1) ;;;(cons 73 2) ;; ;; ;;============================ (entmake (list (cons 0 "TEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbText") (cons 1 TextString);string (cons 7 TextStyle);style (cons 8 TextLayer);layer [color=red](cons 62 11);color[/color] (cons 10 InsPoint);insertion point (cons 11 InsPoint);alignment point (cons 40 TextHeight);text height (cons 41 TextWidth);text width (cons 50 TextAngle);1.5708 - vertical, 0.0 - horizontal (cons 51 0.0);oblique angle (cons 71 0);alignment flag (cons 72 1);alignment flag (cons 73 2);alignment flag ) ) (vla-endundomark ActiveDocObj) ) ) ) (princ) ) ~'J'~ Quote
