I'm trying to write a program that will open all Advance Steel detail drawings from a model, but I'm a little stuck.
So far it will find all the detail drawings, but I'm not sure how to proceed from here.
(defun c:DDD (/)
  (vl-load-com)
  (setq DwgName (getvar 'DWGNAME)
	DirPath (strcat (getvar 'DWGPREFIX) (substr DwgName 1(- (strlen DwgName) 4)) "\\Details")
	);setq
  (if (vl-file-directory-p DirPath)
    (setq DwgFiles (vl-directory-files DirPath "*.dwg"))
    );if
(defun open_file (FileName ReadOnly / )
    (vla-Open
     (vla-get-Documents
      (vlax-get-Acad-Object)
     FileName
     (if ReadOnly
      :vlax-true
      :vlax-false
You can use this.  Last I checked this worked.
So, something like this.  I haven't checked if it works.  If it doesn't, then let me know
(setq i 0)
(repeat (length DwgFiles)
  (open_file (nth i DwgFiles) nil)
  (setq i (+ i 1))
Might want to have a check (if (> (lenght lst) #) confirm opening all drawings.
;; OPEN DRAWINGS IN FOLDER
(defun C:DDD (/ path fp lst)
  (setq path (strcat (getvar 'DWGPREFIX) "\\Navagate to folder and hit save")
        fp (getfiled "Block List:" path "" 33)
        path (vl-filename-directory fp)
        lst (vl-directory-files path "*.dxf" 1)
        acDocs (vla-get-documents (vlax-get-acad-object))
  (if lst
    (foreach drawing lst
      (vla-open acDocs (strcat path "\\" drawing))
