Civil 3D Solution Tips
CAD Panacea
If you would like to automate the enabling or disabling of the Civil 3D setting shown in the dialog below, read on.
http://cadpanacea.com/wp/wp-content/uploads/2022/06/1Options1.png
Here is some lisp code you can put in one of your startup routines. This example disables the checkbox shown. Change the last “0” to a “1” to check this box. You would only need to do this once, so no need to do it for each document load. Tested with Civil 3D 2019 and 2022.
(vl-registry-write
  (strcat "HKEY_CURRENT_USER\\"
          (vlax-machine-product-key)
          "\\Profiles\\"
          (getvar "cprofile")
          "\\Preferences\\AECBase80")
     "DraftWarningSymbol"
      0
With this knowledge, you can probably figure out how to control other items on the AEC Editor tab 😉
View the full article
