Hi,
I want to calculate a percentage value when itterating a List
Each item in the list has 2 elements:
  • ID (e.g. H601_000001)
  • TRUE or FALSE
The ID element is split in 2 parts where the underscore is the divider:
  • H601 is a location (the amount of Locations will always vary)
  • 00001 is serial number  (the amount of serial numbers will always vary per Location)
Each item of the list also has a TRUE or FALSE element.
Below is an example List of 3 Locations ( H601, H602 and H603)
((H601_000001 TRUE)(H601_000002 TRUE)(H601_000003 TRUE)(H601_000004 TRUE)(H601_000005 TRUE)(H601_000006 TRUE)(H601_000007 TRUE)(H601_000008 TRUE)(H601_000009 TRUE)(H601_000010 TRUE)(H601_000011 TRUE)(H601_000012 TRUE)(H601_000013 TRUE)(H601_000014 TRUE)(H601_000015 TRUE)(H601_000016 TRUE)(H601_000017 TRUE)(H601_000018 TRUE)(H601_000019 TRUE)(H601_000020 TRUE)(H601_000021 TRUE)(H601_000022 TRUE)(H601_000023 TRUE)(H601_000024 TRUE)(H601_000025 TRUE)(H601_000026 TRUE)(H601_000027 TRUE)(H601_000028 TRUE)(H601_000029 TRUE)(H601_000030 TRUE)(H601_000031 TRUE)(H601_000032 TRUE)(H602_000001 TRUE)(H602_000002 TRUE)(H602_000003 TRUE)(H602_000004 TRUE)(H602_000005 TRUE)(H602_000006 TRUE)(H602_000007 TRUE)(H602_000008 TRUE)(H602_000009 TRUE)(H602_000010 TRUE)(H602_000011 TRUE)(H602_000012 TRUE)(H602_000013 TRUE)(H602_000014 TRUE)(H602_000015 TRUE)(H602_000016 TRUE)(H602_000017 TRUE)(H602_000018 TRUE)(H602_000019 TRUE)(H602_000020 TRUE)(H602_000021 TRUE)(H602_000022 TRUE)(H602_000023 TRUE)(H602_000024 TRUE)(H602_000025 TRUE)(H602_000026 TRUE)(H602_000027 TRUE)(H602_000028 TRUE)(H602_000029 TRUE)(H602_000030 TRUE)(H602_000031 TRUE)(H602_000032 TRUE)(H603_000001 TRUE)(H603_000002 TRUE)(H603_000003 TRUE)(H603_000004 TRUE)(H603_000005 TRUE)(H603_000006 TRUE)(H603_000007 TRUE)(H603_000008 TRUE)(H603_000009 TRUE)(H603_000010 TRUE)(H603_000011 TRUE)(H603_000012 TRUE)(H603_000013 TRUE)(H603_000014 TRUE)(H603_000015 TRUE)(H603_000016 TRUE)(H603_000017 TRUE)(H603_000018 TRUE)(H603_000019 TRUE)(H603_000020 TRUE)(H603_000021 TRUE)(H603_000021 FALSE)(H603_000022 TRUE)(H603_000022 FALSE)(H603_000023 TRUE)(H603_000023 FALSE)(H603_000024 TRUE)(H603_000024 FALSE)(H603_000025 TRUE)(H603_000025 FALSE)(H603_000026 TRUE)(H603_000026 FALSE)(H603_000027 TRUE)(H603_000027 FALSE)(H603_000028 TRUE)(H603_000028 FALSE)(H603_000029 TRUE)(H603_000029 FALSE)(H603_000030 TRUE)(H603_000030 FALSE)(H603_000031 TRUE)(H603_000031 FALSE)(H603_000032 TRUE)(H603_000032 FALSE))
I want to calulate foreach Location the percentage of the amount of TRUE values and store this in a new List e.g.:
((H601 100) (H602 83) (H603 51))
What is the best approach for this?
probably could do this easier with lambda but this gets the job done.
(defun LIST-COUNT (lst match / lst-match result)
  (vl-load-com)
  (foreach x lst                                                              ;for each item in list
    (if (eq (vl-symbol-name (cadr x)) match)                                  ;if 2nd item in mini list match what your looking for
      (setq lst-match (cons (substr (vl-symbol-name (car x)) 1 4) lst-match)) ;add first item in mini list first 4 letters to a new list
  (foreach x lst-match                                                        ;step thought each match and count them
    (setq Result
      (if (setq Item (assoc x Result))                                        ;if match is in results list
        (subst (cons x (1+ (cdr Item))) Item Result)                          ;1+ to the count
        (cons (cons x 1) Result)                                              ;add new item to the results list with a count of 1
  Result
Results
(list-count list-name "TRUE")
(("H601" . 32) ("H602" . 32) ("H603" . 32))
(list-count list-name "FALSE")
(("H603" . 12))
--edit
O you want whats the % off true in the list. will take a little more calculations one sec.
Edited by mhupp
This will get your %
(defun LIST% (lst find / x a b lst-match lst-base item base match result)
  (vl-load-com)
  (foreach x lst
    (setq lst-base (cons (substr (vl-symbol-name (car x)) 1 4) lst-base))
  (foreach x lst
    (if (eq (vl-symbol-name (cadr x)) find)
  (foreach x lst-base
    (setq base
      (if (setq item (assoc x base))
        (subst (cons x (1+ (cdr item))) item base)
        (cons (cons x 1) base)
    (setq match
      (if (setq item (assoc x match))
        (subst (cons x (1+ (cdr item))) item match)
        (cons (cons x 1) match)
  (foreach x base
    (setq a (car x))
    (setq b (atof (rtos (cdr x) 2 1))) ;better way?
    (setq result
      (if (setq item (assoc a match))
        (cons (cons a (fix (* (/ (cdr item) b) 100))) result)
  (reverse result)
results
(LIST% list-name "TRUE")
(("H603" . 72) ("H602" . 100) ("H601" . 100))
--edit
0% won't show
Edited by mhupp
Thanx man, this works!
I have changed the code a bit because I got an error on "vl-symbol-name" and (substr (vl-symbol-name (car x)) 1 4) is not always 4, but there is always an underscore in the string
(defun SplitStr ( s d / p )
    (if (setq p (vl-string-search d s))
    (cons (substr s 1 p) (SplitStr (substr s (+ p 1 (strlen d))) d))
    (list s)
(defun classify (lst find / x int a b lst-match lst-base item base match result)
  (vl-load-com)
  (foreach x lst
    (setq lst-base (cons (car (SplitStr (car x) "_")) lst-base))
  (foreach x lst
    (if (eq (cadr x) find)
      (setq lst-match (cons (car (SplitStr (car x) "_")) lst-match))
  (foreach x lst-base
    (setq base
    (setq match
  (foreach x base
    (setq a (car x))
    (setq result
  (reverse result)
Nice Mhupp was looking for (vl-symbol-name (car x)) not sure why list is not (("H601_000001" "TRUE")("H601_000002" "TRUE")
I am looking at different method sorting all in list and count duplicates, used this in up to 5 items in each sub list.
Like lots of testing not behaving but in full code works perfect.
Gsc nice to know about "_" will include if get working.
  • Agree 1
1. Yeah like BIGAL said your list wasn't strings so had to use vl-symbol-name for it to work for me.
2. about not always being 4 long but having a underscore updated code to trim right of underscore.
(defun LIST% (lst find / x a b lst-match item base match result)
  (vl-load-com)
  (foreach x lst
    (setq x (cons (vl-string-right-trim "_" (car x)) lst-base))
  (foreach x lst
      (setq lst-match (cons (vl-string-right-trim "_" (car x)) lst-match))
    (setq match
  (foreach x base
    (setq a (car x))
    (setq result
  (reverse result)
Yeah sorry, I just typed a list but forgot they are both string elements
@mhupp like your update, more efficient
I have one other issue. There is no result if all ID's of 1 location are FALSE
Then the percentage should be 0
I solved this with below code....is there a better way to do this?
  (foreach x base
    (setq a (car x))
    (setq result
        ) ;added a progn!
        (cons (cons a 0) result) ;added this line!
  (reverse result)
looks good but progn isn't needed unless you are running multiple lines of code
(setq result
Maybe something like this?
(defun f ( l / n r y )
    (foreach x l
        (setq n (if (= "true" (strcase (cadr x) t)) 1 0)
              x (car x)
        (if (setq y (vl-some '(lambda ( y ) (if (wcmatch x (strcat (car y) "*")) y)) r))
            (setq r (subst (list (car y) (+ n (cadr y)) (1+ (caddr y))) y r))
            (setq r (cons  (list (substr x 1 (vl-string-position 95 x)) n 1.0) r))
    (mapcar '(lambda ( x ) (list (car x) (apply '/ (cdr x)))) r)
_$ (f lst)
(("H603" 0.727273) ("H602" 1.0) ("H601" 1.0))
  • Like 3
(╯°□°)╯︵ ┻━┻    No really I'm in aw hopefully one day ill get there.
