XDSoft Posted April 23, 2024 Posted April 23, 2024 On 4/15/2024 at 9:21 PM, pkenewell said: I recommend that you also provide instructions on your GITHUB on how to download and install the ObjectARX Library properly. Maybe also start a "releases" section? I have made a compressed package version, no EXE is required, you can try it if you are interested. https://github.com/xdcad/XDrx-API-zip https://github.com/xdcad Quote
XDSoft Posted April 23, 2024 Posted April 23, 2024 On 4/17/2024 at 12:10 AM, Steven P said: Yes, welcome to the corporate world. I have made a compressed package version, no EXE is required, you can try it if you are interested. https://github.com/xdcad/XDrx-API-zip https://github.com/xdcad Quote
Nikon Posted 1 hour ago Posted 1 hour ago On 7/14/2022 at 1:54 AM, ronjonp said: And another that allows a pick of any part of the dimension (defun c:foo (/ e el m p1 p2) (if (and (setq e (car (entsel "\nPick dimension: "))) (progn (vlax-for a (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget e))) ) (and (= "AcDbMText" (vla-get-objectname a)) (setq m (vlax-vla-object->ename a))) ) m ) (setq p1 (cdr (assoc 10 (setq el (entget m))))) (setq p2 (getpoint p1 "\nSpecify second point: ")) ) (entmakex (append (vl-remove-if '(lambda (x) (= 330 (car x))) el) (list (cons 10 p2)))) ) (princ) ) How can I convert the text size for insertion to the number x by 0.001, that is, if the size is 4250, then we get 4.250 when inserting? Thanks! Quote
