XDSoft Posted April 23, 2024 Posted April 23, 2024 On 4/15/2024 at 9:21 PM, pkenewell said: I recommend that you also provide instructions on your GITHUB on how to download and install the ObjectARX Library properly. Maybe also start a "releases" section? I have made a compressed package version, no EXE is required, you can try it if you are interested. https://github.com/xdcad/XDrx-API-zip https://github.com/xdcad Quote
XDSoft Posted April 23, 2024 Posted April 23, 2024 On 4/17/2024 at 12:10 AM, Steven P said: Yes, welcome to the corporate world. I have made a compressed package version, no EXE is required, you can try it if you are interested. https://github.com/xdcad/XDrx-API-zip https://github.com/xdcad Quote
Nikon Posted yesterday at 11:33 AM Posted yesterday at 11:33 AM On 7/14/2022 at 1:54 AM, ronjonp said: And another that allows a pick of any part of the dimension (defun c:foo (/ e el m p1 p2) (if (and (setq e (car (entsel "\nPick dimension: "))) (progn (vlax-for a (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget e))) ) (and (= "AcDbMText" (vla-get-objectname a)) (setq m (vlax-vla-object->ename a))) ) m ) (setq p1 (cdr (assoc 10 (setq el (entget m))))) (setq p2 (getpoint p1 "\nSpecify second point: ")) ) (entmakex (append (vl-remove-if '(lambda (x) (= 330 (car x))) el) (list (cons 10 p2)))) ) (princ) ) How can I convert the text size for insertion to the number x by 0.001, that is, if the size is 4250, then we get 4.250 when inserting? Thanks! Quote
ronjonp Posted 19 hours ago Posted 19 hours ago (edited) Something like this? (defun c:foo (/ d e el m p1 p2) (cond ((and (setq e (car (entsel "\nPick dimension: "))) (vlax-property-available-p (vlax-ename->vla-object e) 'measurement) (setq d (vla-get-measurement (vlax-ename->vla-object e))) (progn (vlax-for a (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget e))) ) (and (= "AcDbMText" (vla-get-objectname a)) (setq m (vlax-vla-object->ename a))) ) m ) (setq p1 (cdr (assoc 10 (setq el (entget m))))) (setq p2 (getpoint p1 "\nSpecify second point: ")) ) (setq e (entmakex (append (vl-remove-if '(lambda (x) (= 330 (car x))) el) (list (cons 10 p2)))) ) (vla-put-textstring (setq e (vlax-ename->vla-object e)) (vl-princ-to-string (* 0.001 d))) (vla-put-rotation e 0.) ) ) (princ) ) Edited 2 hours ago by ronjonp 1 Quote
Nikon Posted 11 hours ago Posted 11 hours ago (edited) 8 hours ago, ronjonp said: (vla-put-height (setq e (vlax-ename->vla-object e)) (* 0.001 (vla-get-height e))) @ronjonp thanks. This code reduces the height of the text, but I need to reduce the dimension value (x 0.001) and insert the text (angle text 0, text height = height of the dimtext). Edited 11 hours ago by Nikon Quote
Nikon Posted 10 hours ago Posted 10 hours ago (edited) On 7/13/2022 at 8:31 PM, mhupp said: ;; Copy dimension value to another location (defun C:DimCopy (/ dim BP LastEnt en) Probably, for my task, it will be easier to change the @mhupp code. ;; Copy dimension value to another location (x0.001) + text angle = 0 ;; DimCopy.lsp the original / creator mhupp ;; https://www.cadtutor.net/forum/topic/75587-help-with-extracting-text-from-one-dimension/#findComment-597630 ;; modification using AI (defun _DimCopy001:OnlyNum (s / lst out c) ;; we leave only numbers, minus sign, period/comma (setq lst (vl-string->list s) out "") (foreach c lst (if (member c (vl-string->list "0123456789-.,")) (setq out (strcat out (chr c))) ) ) ;; comma -> period (vl-string-subst "." "," out) ) (defun _DimCopy001:SetText (e / ed txt num new r50) (setq ed (entget e) txt (cdr (assoc 1 ed))) ;; change the text to *0.001 (if (and txt (/= txt "")) (progn (setq txt (_DimCopy001:OnlyNum txt)) (if (and txt (/= txt "")) (progn (setq num (atof txt)) (setq new (rtos (* num 0.001) 2 3)) ; for example 4250 -> 4.250 (setq ed (subst (cons 1 new) (assoc 1 ed) ed)) ) ) ) ) ;; ang 0 (DXF 50) (if (setq r50 (assoc 50 ed)) (setq ed (subst (cons 50 0.0) r50 ed)) (setq ed (append ed (list (cons 50 0.0)))) ) (entmod ed) (entupd e) ) (defun C:DimCopy001Txt (/ dim BP LastEnt en obj oldEcho) (vl-load-com) (setq oldEcho (getvar 'cmdecho)) (setvar 'cmdecho 0) (while (setq dim (car (entsel "\nSelect Dimension: "))) (setq obj (vlax-ename->vla-object dim)) (setq BP (vlax-get obj 'TextPosition)) (setq LastEnt (entlast)) (command "_.Copy" dim "" "_non" BP (getpoint BP "\nCopy to: ")) (command "_Explode" (entlast)) (if (setq en (entnext LastEnt)) (while en (cond ((= "MTEXT" (cdr (assoc 0 (entget en)))) (command "_Explode" en) ; convert mtext to text ) ((= "TEXT" (cdr (assoc 0 (entget en)))) (_DimCopy001:SetText en) ; <<< scale + angle 0 ) (t (entdel en) ) ) (setq en (entnext en)) ) ) ) (setvar 'cmdecho oldEcho) (princ) ) Perhaps this code can be made prettier and shorter... Edited 10 hours ago by Nikon Quote
ronjonp Posted 2 hours ago Posted 2 hours ago 8 hours ago, Nikon said: @ronjonp thanks. This code reduces the height of the text, but I need to reduce the dimension value (x 0.001) and insert the text (angle text 0, text height = height of the dimtext). Code updated above ... give it a try! 1 Quote
Nikon Posted 2 hours ago Posted 2 hours ago 28 minutes ago, ronjonp said: Code updated above ... give it a try! @ronjonp Yes, thank you very much. It's perfect now! Sorry for explaining it wrong at the beginning. Quote
ronjonp Posted 1 hour ago Posted 1 hour ago 40 minutes ago, Nikon said: @ronjonp Yes, thank you very much. It's perfect now! Sorry for explaining it wrong at the beginning. Glad to help : ) 1 Quote
