abcdef1234 Posted August 2, 2022 Posted August 2, 2022 (edited) ;VPFL - VP Freeze Layer ;(discussion forum routine, modified by XANADU) ; (defun c:VZ ( / ent cLayer pLayer) (setq ent (car(entsel "\nSelect object to VP-freeze layer: "))) (setq cLayer (getvar "clayer")) (setq pLayer (cdr (assoc 8 (entget ent)))) (if (= pLayer cLayer) (command "_.layer" "_s" "0" "_off" pLayer "") (command "_.vplayer" "_f" pLayer "_c" "") ) (prompt (strcat "Layer " pLayer " frozen in current viewport")) (princ) ) using vp freeze lisp i want to unfreeze lisp in viewport Edited August 3, 2022 by SLW210 Added Code Tags Quote
Emmanuel Delay Posted August 3, 2022 Posted August 3, 2022 Thaw, that's the opposite of freeze. ;; unfreeze layer in Viewport (defun c:ulvp ( / lay) (setq lay (getstring "\nLayer to unfreeze: ")) (command "_VPLAYER" "Thaw" lay "Current" "") ) Quote
