When copying a layout tab, you're prompted to select where you want to insert the new tab. Trouble is, with this box at least, the new tab gets inserted not in the place I intended. I double and triple checked this to insure it was happening and sure enough, the new tab did not always end up where I intended it to. Sometimes it was okay, but most of the time I end up moving the tab to the location where I want it after it gets copied.
Pretty sure there is a reorganize layout tabs in sorted order somewhere.
Re-ordering layout tabs? - AutoLISP, Visual LISP & DCL - AutoCAD Forums (cadtutor.net)
mhupp tested in Bricscad
Edited by BIGAL
