halfcracked Posted August 4, 2022 Posted August 4, 2022 I've found that editing the AcFields.fdc file allows me to add new custom fields specifically area calculations that read in Acres and ones that are formatted as xxx,xxx S.F. for our site planning. The issue I have is that AcFields.fdc is stored in C:\Users\xxx\AppData\Roaming\Autodesk\ACA 2016\enu\Support where xxx is the user name. I tried copying the file to a network location that is in the profile search path but Autocad ignores it there. I want to standardize this for multiple users but would rather not have to copy files to their local support directory. Quote
BIGAL Posted August 4, 2022 Posted August 4, 2022 I dont have Architectural but if you type CONFIG then FIles is there a pointer to the location of the fdc. Like this Maybe Quote
tombu Posted August 5, 2022 Posted August 5, 2022 Wouldn't it be a lot easier to simply use lisp formatted to specify area calculations that read in Acres and ones that are formatted as xxx,xxx S.F. and add it to a common support folder for everyone? Your method would cause issues for everyone who didn't have your version of the AcFields.fdc file and would be the same program every time you updated AutoCAD. AutoCAD has updated that file before and probably will again in the future. Quote
halfcracked Posted August 5, 2022 Author Posted August 5, 2022 1 hour ago, tombu said: Wouldn't it be a lot easier to simply use lisp formatted to specify area calculations that read in Acres and ones that are formatted as xxx,xxx S.F. and add it to a common support folder for everyone? Your method would cause issues for everyone who didn't have your version of the AcFields.fdc file and would be the same program every time you updated AutoCAD. AutoCAD has updated that file before and probably will again in the future. I've found fields to be very useful for site planning when things are shifting repeatedly. The field updates with a regen where a lisp would need to be run every time. Right now I have some workstations setup with the updated AcFields & it is not causing problems. Already inserted fields contain the formatting in the field not the Acfields file. fixing the file just simplifies the initial setup of the field. as to updates - that's why I want to set a network location for the file - Set the user profile to look for the file on the network & I only need to maintain 1 copy of the file. plus -> Back-up. Quote
BIGAL Posted August 5, 2022 Posted August 5, 2022 (edited) Providing you have an object supporting an area a field will update automatically when you change a shape, using lisp to create the field formula. So many area -> field lisp. Did you check the Archi project defaults did that help ? Edited August 5, 2022 by BIGAL 1 Quote
tombu Posted August 6, 2022 Posted August 6, 2022 6 hours ago, halfcracked said: I've found fields to be very useful for site planning when things are shifting repeatedly. The field updates with a regen where a lisp would need to be run every time. Most of us use fields on a daily basis. Just saying you don't have to modify the AcFields.fdc file to do what you want. I use lisp to label areas in acres, SF, or SY without modifying and AutoCAD files. Your method seems a little extreme. Quote
halfcracked Posted 22 hours ago Author Posted 22 hours ago On 8/5/2022 at 11:08 PM, tombu said: Most of us use fields on a daily basis. Just saying you don't have to modify the AcFields.fdc file to do what you want. I use lisp to label areas in acres, SF, or SY without modifying and AutoCAD files. Your method seems a little extreme. I use the fields to calculate acreage not a strait forward option in standard fields that come with out of the box. I was able to add "Acres" to the pulldown list through the AcFields file and quickly force the conversion from SI to acres. Quote
tombu Posted 21 hours ago Posted 21 hours ago On 8/4/2022 at 4:48 PM, halfcracked said: I've found that editing the AcFields.fdc file allows me to add new custom fields specifically area calculations that read in Acres and ones that are formatted as xxx,xxx S.F. for our site planning. The issue I have is that AcFields.fdc is stored in C:\Users\xxx\AppData\Roaming\Autodesk\ACA 2016\enu\Support where xxx is the user name. I tried copying the file to a network location that is in the profile search path but Autocad ignores it there. I want to standardize this for multiple users but would rather not have to copy files to their local support directory. Sound like the hard way having to update it for every user every time a new version is installed that could be overwritten by an AutoCAD update. I use a Slightly modified version of older version of Lee's code https://www.lee-mac.com/areastofield.html you can find at https://www.cadtutor.net/forum/topic/71208-area-lisp-help/#elControls_571948_menu that labels with selected area or lengths units included. I added the scaled versions of "sqft" for labeling X-Section areas which usually have exaggerated vertical scale for an engineer who wanted it. Tremendous amount of functions in a custom CUI with all code in a network Trusted Support folder. Quote
halfcracked Posted 19 hours ago Author Posted 19 hours ago it is a pain. that's why I'm trying to find a way to make ACAD use the file in a different location. much like I do for printer configuration files. Quote
tombu Posted 18 hours ago Posted 18 hours ago 1 hour ago, halfcracked said: it is a pain. that's why I'm trying to find a way to make ACAD use the file in a different location. much like I do for printer configuration files. Good luck! I did it the same as you many years ago. If you find a solution post it here. Quote
BIGAL Posted 15 hours ago Posted 15 hours ago (edited) Just a maybe (setq who (getenv "username")) hopefully that matches the XXXX, can use a vl copy file or a shell to copy the modified file. For the correct user. For me I use a Install lisp when I do a new CAD install/update so that file copy could be part of it. Edited 15 hours ago by BIGAL Quote
SLW210 Posted 1 hour ago Posted 1 hour ago It could be done, but seems a hassle and inefficient. AutoCAD decides where to look based on a mix of profiles, support paths, and environment variables from what I can determine. It is "intentionally" made to not be used on a network to be shared. You will have to use any number of "tricks" to get it to work that way, even then you may have file locks, slow performance, etc.. Your best bet is to just update on each computer when needed. Quote
