Hi everyone! I wonder if there a possible lisp that would work exactly like the extend command but instead of extending the lines, it would indicates the dimensions of the gap! I would like to select the destination line or lines (blue in this dwg) and after that, select the lines (white in this dwg) to show the dimensions in between! Can the dimensions be set at 1/2" to the right of the lines? Note that the colors don't matter, it is just for clarification!
Thanks for looking at this!
extend-dimensions.dwg
Edited by stlo
New dwg
A method no code
Pick blue line
Pick white lines end near Blue line this is important
Get closestpointto for 90 deg to blue line
Then just do dim pt1 pt2 pt3 where pt3 is the 1/2 off white line point.
Hi BIGAL! Thanks for the reply! I'm not sure what to do? When you say "method no code", do you mean I can do all this with one or many  existing  autocad command?
