I'm using AC 2000, I can't delete any objects or viewports in paperspace. The layers are all turned on. Even when I open a new draw, the problem remains. Probably I've changed template properties, and can't turn it to default. Can you help me please?
Welcome to the forum!
How are you deleting the objects? Using ERASE command?
If you are highlighting the objects and then pressing the DEL key, make sure PICKFIRST is set to 1, otherwise the DEL key has no effect.
That's it!! PICKFIRST was set to 0. Now with new value everything is ok. Never heard about that comand, but the erase comand worked just fine, and DEL key woun't work, with PICKFIRST set to 0.
Thank you for your replies.
