Nag-BU Posted August 16, 2022 Posted August 16, 2022 Can we create a slides for multiple DWG files in one shot in AutoCAD-2019 normal application, like similar to AMSCRIPT in AutoCAD mechanical which creates multiple slides for selection. (In AutoCAD-2019, presently we have MSLIDE option which creates only one slide for currently opened drawing.) Quote
BIGAL Posted August 22, 2022 Posted August 22, 2022 (edited) If you look at how a slide is made then yes. Simplest is a script say insert block at 0,0 then Mslide save as block name. I have made hundreds this way. What is it your trying to make slides of blocks 1 dwg or multi dwg,s blocks within . Explain more and can help note screen resolution also creeps in. Last question what are the slides being used In Dcl or menu,s Edited August 23, 2022 by BIGAL Quote
SLW210 Posted August 22, 2022 Posted August 22, 2022 Doesn't AutoCAD 2019 come with the tool set that includes access to Mechanical? Quote
