Need help with following, I want to write lisp to save drawing. I have the following:
(setq dxfname (strcat (vl-filename-base (getvar "dwgname"))))
(command "SAVEAS" "DXF" "VERSION" "2000" "" (strcat (getvar "dwgprefix") dxfname))
And when there already is a drawing with the same name, I get this message: "A drawing with this name already exists." and in that case I'd like to have DCL pop up and ask me if I want to replace it or not. My problem is how to save that command line text to create if function, something like
(if
(= message "A drawing with this name already exists.")
Or if there is any other way to do what I want, please write your solutions, thanks!
This is quite a simple one to use@
http://www.lee-mac.com/popup.html
put in something like
(setq Answer (LM:popup "Title Text" "This is a test message." 4) )
(if (= Answer 6)
    (princ "Yes")
  ) ;end progn
    (princ "No")
  ) ;end progn
) ;end if
(if (= Answer 6)
    (princ "Yes")
  ) ;end progn
    (princ "No")
  ) ;end progn
) ;end if
Thanks for this, but I created the DCL pop up, that is not the problem here. Problem is how to know if it needs to ask for replacement. for example here, if a drawing already exist (message "A drawing with this name already exists.") then (setq Answer (LM:popup "Save as dxf" "Overwrite existing dxf?" 1)). If not then just save as, no pop up needed. Hope I explained enough
I was answering the worng thing then, how about this:
(if dxfname
    (princ "File Exists)
  ) ; End progn
    (princ File Doesn't exist")
  ) ; End progn
) ; end if
(if dxfname
  ) ; End progn
  ) ; End progn
) ; end if
No, even though drawing is not saved, dxfname variable exist (Drawing1, Drawing2,...)
You could try
(if (= (getvar 'DWGTITLED) 0)
  (princ "Drawing Not Saved")
  (princ "drawing Saved")
to find out if the drawing has been saved
Edited by Steven P
