hildevasco_br Posted August 16, 2022 Posted August 16, 2022 Hello Could someone help me, I need to access a txt file to read a folder on a server by ip with visual lisp Example: Folder: https://xxx.xxx.xxx.xxx/d://teste/arquivoteste.txt Where: xxx.xxx.xxx.xxx and the ip address or ftp.xxxxx.com.br test is a folder on the D:// drive testfile.txt is the file to be read to retrieve the content Thanks hildevasco Quote
fan_zh Posted August 19, 2022 Posted August 19, 2022 (edited) try this code (defun get (url / outtext xml) (setq xml (vlax-create-object "Microsoft.XMLHTTP")) (vlax-invoke xml 'open "GET" url 0) (vlax-invoke xml 'setrequestheader "If-Modified-Since" 0) ;_ (vlax-invoke xml 'send) (setq outtext (vlax-get xml "responseText")) (vlax-release-object xml) (princ outtext) (princ) ) Edited August 19, 2022 by fan_zh Quote
