Access and edit titleblock through autolisp? - EDIT: Need help with multi-variable lambda
Hello,
I'm trying to automate my titleblock to remove possibility of silly errors.
The titleblock is edited through an enhanced attribute editor.  How would I go about accessing it through autolisp?
Thanks!
EDIT: Well, I should try more before I ask - you can access the data through vlax-invoke!  I'm leaving this up so others who are looking can find this useful.
Does anyone have a list of vlax-invoke values?  Right now I'm using 'getattributes but I'd like to see what is possible.
I'm going to use this thread as a live update of my progress.  When I try using (apply 'vla-get-textstring attributes), I get a warning for having too many parameters!  What is the limit for apply, and is there a workaround?
Since I'm just using this for info, what do you pass into a multivariate lambda function?  i.e. (lambda (x y ) (x + y) lst) what would be lst?
  (setq todo (list  (list 0 "1")
         	    (list 1  (strcat getMM "-" getDD "-" getYY))
           	    (list 2  name)
           	    (list 3 "Initial Release.")
         	    (list 33  name)
         	    (list 34  name)
         	    (list 35  sheetnum)
          	    (list 24  projname)
  (mapcar '(lambda (no na) (vla-put-textstring (nth no atts) na)) (todo))
Is what I have now, but it doesn't work at all.
Edited by TemporaryCAD
Would this be any use?
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/edit-attribute-value-with-lisp/td-p/6927162
If you want to set up several drawings you can also look at Lee Macs Batch Attribute Editor - hands with a border to put in client details in a series for example, not so good to out in individual details like a drawing title - but does what it does very well
Edited by Steven P
  • TemporaryCAD changed the title to Access and edit titleblock through autolisp? - EDIT: Need help with multi-variable lambda
For list 1
(menucmd "M=$(edtime, $(getvar,date),DD-MO-YYYY)")
Edited by mhupp
