Is it possible to read-line of a text file after a comma?
For example:
Line 1 will have: TEST1,TOS %%script(Q = (%ObjectTopLevel): If Q>0 then appendstring ("+" & (FormatNumber(Q,3))) else appendstring (FormatNumber(Q,3)))
But the list box will only show: TOS %%script(Q = (%ObjectTopLevel): If Q>0 then appendstring ("+" & (FormatNumber(Q,3))) else appendstring (FormatNumber(Q,3)))
My current code segment to read a file:
  (setq LC nil)
  (setq OpenFile (open (findfile "LabelContent.cfg")"R"))
  (while (setq line (read-line OpenFile))
    (setq LC (cons line LC))
    );while
  (setq LC (reverse LC))
  (close OpenFile)
  (dcl-ListBox-AddList LabelContent/Form1/ListBox1 LC)
;Takes a string, substring, and offset
;Will trim the line to everything BEFORE the substing.  The offset edits directly (i.e. -1 = one less char, 1 = one more char)
;If nothing is found, returns original string
(defun trimbefore (str sstr offset / cut rstr)
  (setq cut (vl-string-search sstr str)
        rstr str
  (if (/= cut nil)
    (setq rstr(substr str 1 (+ cut offset)))
  (princ rstr)
;Will trim the line to everything AFTER the substring.  The offset edits directly (i.e. -1 = one less char, 1 = one more char)
(defun trimafter (str sstr offset / cut rstr)
        rstr str
  (if (/= cut nil)
    (setq rstr(substr str (- cut offset)))
  (princ rstr)
I wrote these for some file handling.  It works with vl-string-search, so beware if there are multiple substring matches.
Read the text after a comma. I like it when I can do many things with as few commands as i can. Makes remembering then easier. A file, text seperated by commas..... hmm similar to a comma separated valuies (CSV file)., in which case my second favourite thing, Lee Mac usually has a solution:
http://lee-mac.com/readcsv.html
I haven't checked to see if this will work for your sample though. This is longer than the code above but also includes for getting reading the file too. Might need a small adjustments to say look for .TXT file and not .CSV file perhaps.
If you don't need that go with TemporaryCAD
Like Steven P you can change the delimiter in Lee's code. Just use correct number. (ascii (getstring)) enter the character and a number will appear.
; thanks to Lee-mac for this defun
; www.lee-mac.com
; 44 is comma 9 is tab 34 is space ; is 59
(defun _csv->lst ( str / pos )
	(if (setq pos (vl-string-position 9 str))
		(cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2))))
		(list str)
