I would like to make a hatch pattern that has vertical lines offset at 2 different spacings.  Basically 2 vertical  lines .75 inch apart spaced 16" apart.  Any help would be appreciated as I am having trouble with the code.  Thanks!
You could try:
*CT2, 16" panel
90,0,0,0,16.75
90,16,0,0,16.75
A blank line is essential at the end of a pattern definition, but I have found that AutoCAD tolerates a * in the last line, and it serves as a visual marker
