Resetting and Sorting CANNOSCALES (Issue with this drawing)
Hi all,
See attached the drawing where there are two 1:1 scales. But one is named as 1:1 and the other is 1:1000. I don't know how this came about but it was a drawing I came across in the office this week.
The named 1:1000 scale is greyed out in the Edit Scale GUI.
Perhaps someone could shed some light on how to fix this. I'm www.lost.com.
Thanks in advance.
Here's the code I have ATM which works 60% of the time, every time.
(vl-load-com)
; by Ian_Bryant, 2013-04-25 12:20 PM
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/help-with-lisp-to-sort-cannoscale-list/m-p/3887927#M310705
; Reported bug for not sorting the scale in this reply also.
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/help-with-lisp-to-sort-cannoscale-list/m-p/11381844#M435522
(defun c:Reset_Cannoscale_List_Metric (/ var_cmdecho xpt as3 ndict dict sce sx sl dl xl)
  (setq var_cmdecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq xpt (getvar "expert"))
  (setvar "expert" 5)
  (command "-scalelistedit" "reset" "yes" "exit")
  (command "-scalelistedit" "delete" "*")
  ; List of standard ISO scales (from ISO 13567) below.
  ; "1:1" "1:2" "1:5" "1:10" "1:20" "1:25" "1:50" "1:75" "1:100" "1:200" "1:250" "1:500" "1:750" "1:1000" "1:2000" "1:2500" "1:5000" "1:10000"
  (foreach n '("1:1" "1:2" "1:5" "1:10" "1:20" "1:25" "1:50" "1:75" "1:100" "1:200" "1:250" "1:500" "1:750" "1:1000" "1:2000" "1:2500" "1:5000" "1:10000")
    (command "add")
    (command n)
    (command n)
  (command "exit")
  (setvar "expert" xpt)
  (setvar "cmdecho" var_cmdecho)
  (setq dict (dictsearch (namedobjdict) "acad_scalelist"))
  (setq as3   (assoc 3 dict)
        ndict (cdr (member as3 (reverse dict)))
        dict  (member as3 dict)
  (while (setq as3 (assoc 3 dict))
    (setq dict (member as3 dict)
          dl   (cons (cdr as3) dl)
          sce  (cdr (assoc 350 dict))
    (if (> (setq sx (/ (cdr (assoc 140 (entget sce))) (cdr (assoc 141 (entget sce))))) 1.0)
      (setq xl (cons (cons sx sce) xl))
      (setq sl (cons (cons sx sce) sl))
    (setq dict (cdr dict))
  (setq sl (vl-sort sl '(lambda (x y) (> (car x) (car y)))))
  (if xl (setq sl (append sl (vl-sort xl '(lambda (x y) (< (car x) (car y)))))))
  (setq dl (acad_strlsort dl))
  (setq n 0)
  (repeat (length dl)
    (setq ndict (cons (cons 3 (nth n dl)) ndict)
          ndict (cons (cons 350 (cdr (nth n sl))) ndict)
          n     (1+ n)
  (entmod (reverse ndict))
(c:Reset_Cannoscale_List_Metric)
;;                             End of File                              ;;
Cannoscale List Not Sorted (1).dwg
Edited by 3dwannab
  • 4 months later...
Set 1:1000 scale as current. Eliminate the 1:1 scale. Rename the scale 1:1000 as 1:1. And run the command "Reset_Cannoscale_List_Metric".
Thanks, not sure how I can do this programmatically though as I want to run this command in a batch file.
Try this.
(DEFUN checkScale (scaleName / item)
  (CAR
    (VL-REMOVE-IF-NOT
      (FUNCTION (LAMBDA (item) (EQ scaleName (CDR (ASSOC 300 item)))))
      (MAPCAR (FUNCTION (LAMBDA (item) (ENTGET (CDR item))))
              (VL-REMOVE-IF-NOT
                (FUNCTION (LAMBDA (item) (= (CAR item) 350)))
                (DICTSEARCH (NAMEDOBJDICT) "ACAD_SCALELIST")
(DEFUN rea (/ rae es ce xpt n dict ndict dict dl sce sl xl ndict)
  (SETQ es "1:1000")
  (SETQ ce (checkScale es))
  ;; si existe
  (IF ce
    (PROGN
      ;; seleccionarla
      (COMMAND "_.cannoscale" es)
      (SETQ es "1:1")
      ;; si existe
      (IF ce
        (PROGN
          ;; eliminarla
          (COMMAND "_.-scalelistedit" "_delete" es "_exit")
          ;; renombrarla
          (SETQ rae (rename_annotative_scale "1:1000" es))
          (IF rae
            (PROMPT "\nRenamed annotative scale.")
            (PROMPT "\nThe annotative scale could not be renamed.")
        (PROMPT (STRCAT "\nThe scale " es " does not exist."))
  (SETQ xpt (GETVAR "EXPERT"))
  (SETVAR "EXPERT" 5)
  (COMMAND "_.-scalelistedit" "_Reset" "_Yes" "_Exit")
  (COMMAND "_.-scalelistedit" "_Delete" "*")
  (FOREACH n '("1:1" "1:2" "1:5" "1:10" "1:20" "1:50" "1:100" "1:250" "1:500" "1:1000" "1:2500")
    (COMMAND "_Add")
    (COMMAND n)
    (COMMAND n)
  (COMMAND "_Exit")
  (SETVAR "EXPERT" xpt)
;;;  (SETVAR "CMDECHO" cmde)
  (SETQ dict (DICTSEARCH (NAMEDOBJDICT) "ACAD_SCALELIST"))
  (SETQ as3   (ASSOC 3 dict)
        ndict (CDR (MEMBER as3 (REVERSE dict)))
        dict  (MEMBER as3 dict)
  (WHILE (SETQ as3 (ASSOC 3 dict))
    (SETQ dict (MEMBER as3 dict)
          dl   (CONS (CDR as3) dl)
          sce  (CDR (ASSOC 350 dict))
    (IF (> (SETQ sx (/ (CDR (ASSOC 140 (ENTGET sce))) (CDR (ASSOC 141 (ENTGET sce))))) 1.0)
      (SETQ xl (CONS (CONS sx sce) xl))
      (SETQ sl (CONS (CONS sx sce) sl))
    (SETQ dict (CDR dict))
  (SETQ sl (VL-SORT sl '(LAMBDA (x y) (> (CAR x) (CAR y)))))
  (IF xl
    (SETQ sl (APPEND sl (VL-SORT xl '(LAMBDA (x y) (< (CAR x) (CAR y))))))
  (SETQ dl (ACAD_STRLSORT dl))
  (SETQ n 0)
  (REPEAT (LENGTH dl)
    (SETQ ndict (CONS (CONS 3 (NTH n dl)) ndict)
          ndict (CONS (CONS 350 (CDR (NTH n sl))) ndict)
          n     (1+ n)
  (ENTMOD (REVERSE ndict))
  (COMMAND "_.CANNOSCALE" "1:2500")
  (SETQ x 0)
  (SETQ x (1+ x))
;;;  (PRINC)
 ; return elist of the renamed annotation scale or nil if it fails
(DEFUN rename_annotative_scale (oldsym newsym / isexist table)
  (DEFUN isexist ()
    (VL-SOME
      (FUNCTION
        (LAMBDA (item)
          (AND
            (= (CAR item) 350)
            (EQ (STRCASE (CDR (ASSOC '300 (ENTGET (CDR item))))) (STRCASE newsym))
        ) ; lambda
      ) ; function
      table
    ) ; vl-some
  ) ; isexist
  (COND
    ((NOT (SETQ table (ENTGET (CDADR (MEMBER '(3 . "ACAD_SCALELIST") (ENTGET (NAMEDOBJDICT))))))))
    ((isexist)
     (PROMPT (STRCAT "\nThe annotative scale " newsym " already exists."))
    ) ; case
    ((VL-SOME
       (FUNCTION
         (LAMBDA (item / elist)
           (IF (AND
                 (= (CAR item) 350)
                 (SETQ elist (ENTGET (CDR item)))
                 (EQ (STRCASE (CDR (ASSOC '300 elist))) (STRCASE oldsym))
             (ENTMOD (SUBST (CONS '300 newsym) (ASSOC '300 elist) elist)) ; rename
           ) ; if
         ) ; lambda
       ) ; function
       table
     ) ; vl-some
    ) ; case
  ) ; cond
) ; rename_annoscale
(DEFUN errores_rea (men)
  (SETQ *error* error0)
  (IF (= men "quitar / salir abandonar")
    (PRIN1)
    (PRINC (STRCAT "\nError: " men " "))
  (SETVAR "cmdecho" 1)
  (PRIN1)
(DEFUN c:RenameAnnotativeScale (/ error0)
  (SETVAR "cmdecho" 0)
  (SETQ error0  *error*
        *error* errores_rea
  (IF (> x 0)
    (PROGN
      (PROMPT "\nThis command can only be executed once in the current drawing.")
      (EXIT)
    (rea)
  (PROMPT "\nEnd.")
  (PRIN1)
(PROMPT
  "\nCommand RENAMEANNOTATIVESCALE loaded."
(PRIN1)
