Hi all,
Our drawing numbers come if the form of jobno_stage_year_series so an example is 6101_5.1_22_100.
If was looking to see if it's possible to get the last character only if it's a letter for getting the revision out of it.
So extract the from 6101_5.1_22_100_A but not extract anything from 6101_5.1_22_100
This gets the last character but no if check.
$(upper,$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),1),1))
Edited by 3dwannab
Done, simplified version
$(if,$(eq,$(upper,$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),1),1)),"_"),true,false)
Working version
$(if,$(eq,$(upper,$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),1),1)),"_"),$(upper,$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),0),1)),)
Amazing what reading the help files does. RTFM eh!! 🥴
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-LT/files/GUID-F94A885A-4DA2-432B-AC1A-EB49CC6C1C72-htm.html
Edited by 3dwannab
