CUIx: Display Partial Customization Files (CUIx) in different profiles
Hello,
I need your help with the CUIx (Partial Customization Files) file. I have created Partial Customization Files and when I load it, I don't know how to make it show up in any user profile´.
I want to create a Bundle Addin and provide everyone in the ouer company, but everyone has a different profile and there is a problem with the display CUIx file (Ribbon).
Bundle xml will ensure CUIx is loaded but not displayed in different users profiles.
For each users PC, I can set the ribbon display in Customize Workspace in acad.cuix but it's a lot of manual work.
I hope my description is sufficient
Michal J.
You can load custom cuix via lisp. So you could unload and reload in a different profile.
Not sure if this will say loaded or not as I don't have multiple profiles to check against.
(setq Menu_Path "C:\\CAD-TOOLS\\") ; Path to Menu file
(setq Menu_Name "CAD-TOOLS") ; pop menu to load
(setq Group_Name "xxxMENU") ; groupname assigned in .mnu or .mns file
(if (menugroup menu_Name)
