Buen día tengo este lisp pero necesito ayuda, alguien puede modificar esto por favor me sale el texto muy alejado de la linea y me gustaria que este al centro y eje de la linea(espero me entienda osea que la linea corte el texto)
Quote
Good day I have this lisp but I need help, someone can modify this please I get the text very far from the line and I would like it to be in the center and axis of the line (I hope I understand or see that the line cuts the text)
(defun alg-ang (obj pnt)
(angle '(0. 0. 0.)
(vlax-curve-getfirstderiv
obj
(vlax-curve-getparamatpoint
obj
pnt
(defun C:LL (/ *error* acsp adoc ang fld midp mtx rot sset txtpt)
(defun *error* (msg)
(if
(vl-position
msg
'("console break"
"Function cancelled"
"quit / exit abort"
(princ "Error!")
(princ msg)
(vla-endundomark
(vla-get-activedocument
(vlax-get-acad-object)
(or adoc
(setq adoc
(if (and
(= (getvar "tilemode") 0)
(= (getvar "cvport") 1)
(setq acsp (vla-get-paperspace adoc))
(setq acsp (vla-get-modelspace adoc))
(vla-startundomark
adoc
(if (setq sset (ssget "_:L" (list (cons 0 "*LINE,ARC,CIRCLE,ELLIPSE"))))
(foreach obj
(mapcar 'vlax-ename->vla-object
(vl-remove-if 'listp
(mapcar 'cadr (ssnamex sset))))
(if (not (eq "AcDbArc" (vla-get-objectname obj)))
(setq midp (vlax-curve-getclosestpointto obj
(vlax-curve-getpointatparam obj
( / (- (vlax-curve-getEndParam obj)
(vlax-curve-getStartParam obj)) 2))
(vlax-curve-getpointatdist obj
( / (vla-get-arclength obj) 2)))
(setq ang (alg-ang obj midp))
(if (> pi ang (/ pi 2))
(setq ang (+ ang pi))
(if (> (* pi 1.5) ang pi)
(setq rot (+ ang (/ pi 2)))
(setq txtpt (polar midp rot
(if (zerop (getvar "dimtxt"))
0.1
(/ (getvar "dimtxt") 2)))
(setq fld (strcat "%<\\AcObjProp Object(%<\\_ObjId "
(itoa (vla-get-objectid obj))
">%).Layer>%")
(setq mtx (vlax-invoke
acsp 'AddMText midp 0.0 fld)
(vlax-put mtx 'AttachmentPoint
8
(vlax-put mtx 'InsertionPoint
txtpt
(vlax-put mtx 'Rotation
ang
(princ "\n\t\t\tType LL to label curves with layer name\t")
(prin1)
(vl-load-com)
  • 3 weeks later...
Change this :
(setq txtpt (polar midp rot (if (zerop (getvar "dimtxt")) 0.1 (/ (getvar "dimtxt") 2))) )
To :
(setq txtpt midp)
