i want edit pcode.lsp have show point number in autocad. Can help ?
(defun c:pcode (/ *error* fn f l p ok lay XYZ RL CODE )
 (defun *error* (msg)
   (if    (and f (= (type f) 'FILE))
     (close f) ;close the file
     ) ;_ end of if
   ) ;_ end of defun
 (if (and (setq fn (getfiled "\n" "" "csv;pnt;txt;*" 16)) ; get csv file
   (setq f (open fn "r"))
   ) ;_ end of and
   (while (setq $ (read-line f))
     (setq l (read (strcat "( " (vl-string-translate "," " " $) " )"))) ; retriction layer/pcode without spacing
     (if (setq ok (= (length l) 5)) ; format = '( p x y z d )
(progn (foreach x (list car last)
     (setq l (subst (vl-princ-to-string (x l)) (x l) l)))
       (if (and    (setq lay (last l)
              p      (vl-remove-if-not 'numberp (cdr l))
              ) ;_ end of setq
        (= 3 (length p)) ; format = '( x y z )
        (setq p (trans p 1 0)) ; convert point to ucs
        ) ;_ end of and
     (foreach xyz '(
                        (list
               '(0 . "POINT")
               (cons 8 "XYZ") ;(cons 8 "POINT")
               (cons 10 p)
       (entmakex (eval xyz)) ; create text & point entity foreach supplied dxf data
         (foreach RL '(
                        (list
               '(0 . "TEXT")
               (cons 8 "RL")
               (cons 10 p)
               (cons 1 (rtos (caddr p) 2 2))
               (cons 40 (getvar 'textsize))
            (cons 11 p)
            (cons 71 0) ;Flags 0=Normal, 2=Backward, 4=Upside down
            (cons 72 2) ;Horizontal text justification,0=Left,1=Center,2=Right,4=Center,5=Fit
            (cons 73 1) ;Vertical text justification, 0=Baseline,1=Bottom,2=Middle,3=Top
       (entmakex (eval RL)) ; create text & point entity foreach supplied dxf data
         (foreach code '(
                        (list
               '(0 . "TEXT")
               (cons 8 "CODE")
               (cons 10 p)
               (cons 1 (strcat lay))
            (cons 11 p)
            (cons 73 3) ;Vertical text justification, 0=Baseline,1=Bottom,2=Middle,3=Top
       (entmakex (eval  code)) ; create text & point entity foreach supplied dxf data
(foreach PTNO '(
                        (list
               '(0 . "TEXT")
               (cons 8 "PTNO")
               (cons 10 p)
               (cons 1 (strcat ptnum));HOW TO ADD POINT NUMBER
            (cons 11 p)
       (entmakex (eval  PTNO)) ; create text & point entity foreach supplied dxf data
) ;_ end of foreach
) ;_ end of foreach
) ;_ end of foreach
) ;_ end of foreach
     ) ;_ end of if
       ) ;_ end of progn
(setq $ nil) ; exit invalid format
) ;_ end of if
     ) ;_ end of while
(if (not ok)(alert "Invalid format! Should be PXYZD"))
       ) ;_ end of if
   ) ;_ end of if
 ) ;_ end of defunpcode_AA.LSP
pcode_AA.LSP
