Lisp to put point as geometric center of closed polylines
asdfgh
2 hours ago, asdfgh said:
i found this lisp which is useful for everyone
Better to provide a link to give credit to the author Kent Cooper which would be the source if anyone had any questions about the lisp.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-subfunction-to-get-quot-center-quot-inside-closed-polyline/m-p/8747852#M384196
  • Agree 1
i didn't know who is the author as i got the lisp from a college not from internet but thanks for sharing the author with us he deserves the credit
Here you go. :)
(defun c:Test (/ spc get sel int ent rgn)
  ;;	Author : Tharwat Al Choufi			;;
  ;; website: https://autolispprograms.wordpress.com	;;
  (or *TH:doc*
      (setq *TH:doc* (vla-get-activedocument (vlax-get-acad-object)))
  (setq spc ((if (> (vla-get-activespace *TH:doc*) 0) vla-get-modelspace vla-get-paperspace) *TH:doc*
  (and
    (cond
      ((= 4
          (logand
            4
            (cdr
              (assoc
                70
                (setq get (entget (tblobjname "LAYER" (getvar 'CLAYER))))
       (alert "Current layer is locked. Unlock it and try again <!>")
      ((minusp (cdr (assoc 62 get)))
       (alert "Current layer is off. Turn it on and try again <!>")
      (t get)
    (setq int -1
          sel (ssget "_:L" '((0 . "LWPOLYLINE") (-4 . "=") (70 . 1)))
    (or (zerop (getvar 'PDMODE))
        (setvar 'PDMODE 3)
    (while (setq int (1+ int)
                 ent (ssname sel int)
      (entmake
        (list
          '(0 . "POINT")
          (cons
            10
            (vlax-get (setq rgn (car (vlax-invoke
                                       spc
                                       'addregion
                                       (list (vlax-ename->vla-object ent))
                      'Centroid
      (and rgn (vla-delete rgn))
) (vl-load-com)
It is tricky with the OP wanting the geometric centre of several objects. For a single object AutoCAD has an object snap of geometric centre (not sure about Bricscad, I assume it is similar), place a point there, no LISP required for just that. As above to get the centre if you need that point in a LISP.... for single polylines.
