daniAG Posted September 20, 2022 Posted September 20, 2022 Hello. How can I buy AutoCAD Programming in C/C++ by Mr. Owen Ransen book pdf? thank you. Quote
BIGAL Posted September 21, 2022 Posted September 21, 2022 (edited) Try "XXXXX"  has lots of downloadable books cheap.  You can copy code from "XXXX" in some books.  Post edited. Edited September 21, 2022 by BIGAL Quote
daniAG Posted September 21, 2022 Author Posted September 21, 2022 1 hour ago, BIGAL said: Try "XXXXX"  has lots of downloadable books cheap.  You can copy code from "XXXX" in some books.  Post edited. Thank you for your thorough reply. The chapters of this book are very comprehensive. AutoCAD Programming in C/C++ But only the paper version is found.  Quote
BIGAL Posted September 21, 2022 Posted September 21, 2022 Try Kindle search "C/C++ Autocad" must put Autocad else will only find c++ no extension references. Â Quote
daniAG Posted September 21, 2022 Author Posted September 21, 2022 2 hours ago, BIGAL said: Try Kindle search "C/C++ Autocad" must put Autocad else will only find c++ no extension references. Â thank you. Unfortunately, it is not available in the Kindle store. Kindle eBooks Quote
BIGAL Posted September 22, 2022 Posted September 22, 2022 (edited) Did you look at this  AutoCAD .NET Developer's Guide: Introduction (autodesk.com) Edited September 23, 2022 by BIGAL Quote
daniAG Posted September 23, 2022 Author Posted September 23, 2022 On 22/09/2022 at 04:30, BIGAL said: Did you look at this  AutoCAD .NET Developer's Guide: Introduction (autodesk.com) Hello. No. I mean the C++. I want to have a ARX file from the output of my codes. Quote
BIGAL Posted September 23, 2022 Posted September 23, 2022 Sorry link did not paste  http://docs.autodesk.com/ACD/2010/ENU/AutoCAD .NET Developer's Guide/index.html  Quote
