rendering
what program do you use for rendering??
thanks
Solidworks. There is an add in if you go to your tools menu>add-ins, its called photoworks. there is also a program that came with my version called photoview360. go to the showcase forum and look for the the thread solidworks09 renders
do you know other programs??
what program do you use??
i use Solidworks09 and i use solidworks to render. I dont use any external programs to render. these two were drawn in SW09 and i rendered them in Photoview 360 which came with my solidworks package
i assumed since you posted this in the solidworks forum that you were using solidworks. Acad08 had the mentalray render engine and is very good as well.
my friend told me about Linceovr 3.0...have you ever heard about it??
sorry i havent. Its only been very recent that i started rendering things. hopefully someone will chime in for you
I was quite impressed with the rendered output from solidworks as far as the lighting goes but I wasn't impressed with the available options for creating textures so would always favour 3DS Max for rendering objects with materials.
Those things look more like pictures, Shift.
SW makes it easy to do with small parts/assemblies. When you are dealing with environments like spittle there. I think it becomes more difficult to alter settings like in other programs, but i havent dealt with that.
i think spittles renders look great!
Thanks shift.
Thought these images would display the filename. To be clear, image 1 is done in Solidworks, number 2 in Max.
is solidworks something like ACAD??? because i havent use solidworks but my brother says that is better than ACAD
Solidworks is like Inventor. Nothing like autocad:)
  • 1 month later...
I use Hypershot and have to say its by far the easiest render program i used. Compared to vray for 3dmax, , you can get very similar results without any trouble at all. Great program.
