List file names and feed into a dialog box with preview
iI'm trying to cerate a dialog box which has a list of all .dwg files in a folder (want to be able to add future notes to the folder and it auto update) and the ability to select the item then insert at a specific point
I've created a .lsp file and a .dcl file a few things together but not sure how to piece it together.
I'd also like to be able to show a preview of the block with a .sld in the graphics boxed column
any help/ direction would be appreciated
.lsp:
(defun c:notes (/ p MSpace)
  (vlax-for file (vl-directory-files "C:\\BricsCAD Scripts\\MACROS\\DWG" "*.dwg" 1)
    (princ file)
  (setq p (Getpoint "\nInsertion point")
        MSpace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
  (vla-insertblock
    MSpace
    p
    (strcat "C:\\BricsCAD Scripts\\MACROS\\DWG\\" file_name)) ;note file pulled from dialog selection
    1
    1
    1
    0
.dcl:
NOTES :dialog {
  label = "Select a Note";
  : row {
    : boxed_column {
      label = "Notes";
      : list_box {
        height = 10;
        width  = 25;
        key    = "note_lt";
        multiple_select = true ;
    : boxed_column {
      label = "Preview";
      : image {
        key = "imageP";
        color = graphics_background;
        width = 35;
        height = 15;
  spacer;
  ok_only;
This should do the trick. Edit the headers to what you want. Need to edit the dcl to have an all button.
Example
(setq lst (vl-directory-files "C:\\BricsCAD Scripts\\MACROS\\DWG" "*.dwg" 1))
(if (setq Blklst (AT:ListSelect (strcat (itoa (length lst)) " Block(s) in Folder") "Pick Block(s) to Insert Into Drawing" 30 60 "true" lst))
;; List Select Dialog (Temp DCL list box selection, based on provided list)
;; title - list box title
;; label - label for list box
;; height - height of box
;; width - width of box
;; multi - selection method ["true": multiple, "false": single]
;; lst - list of strings to place in list box
;; Alan J. Thompson, 09.23.08 / 05.17.10 (rewrite)
(defun AT:ListSelect (title label height width multi lst / fn fo d f)
  (setq fo (open (setq fn (vl-filename-mktemp "" "" ".dcl")) "w"))
  (foreach x (list (strcat "list_select : dialog { label = \"" title "\"; spacer;")
                   (strcat ": list_box { label = \"" label "\";" "key = \"lst\";")
                   (strcat "allow_accept = true; height = " (vl-princ-to-string height) ";")
                   (strcat "width = " (vl-princ-to-string width) ";")
                   (strcat "multiple_select = " multi "; } spacer; ok_cancel; }")
    (write-line x fo)
  (close fo)
  (new_dialog "list_select" (setq d (load_dialog fn)))
  (start_list "lst")
  (mapcar (function add_list) lst)
  (end_list)
  (setq item (set_tile "lst" "0"))
  (action_tile "lst" "(setq item $value)")
  (setq f (start_dialog))
  (unload_dialog d)
  (vl-file-delete fn)
  (if (= f 1)
    ((lambda (s / i s l)
       (while (setq i (vl-string-search " " s))
         (setq l (cons (nth (atoi (substr s 1 i)) lst) l))
         (setq s (substr s (+ 2 i)))
       (reverse (cons (nth (atoi s) lst) l))
      item
I forgot to update on where i got to,
my current status on code is:
(defun c:notess (/ p MSpace)
  (defun NInster(ent)
    (print ent)
    (vla-insertblock
      MSpace
      p
      (strcat "C:\\BricsCAD Scripts\\MACROS\\DWG\\NOTES\\" ent)  ;note file pulled from dialog selection
      1
      1
      1
      0
  (setq folderList (vl-directory-files "C:\\BricsCAD Scripts\\MACROS\\DWG\\NOTES" "*.dwg" 1))
  (setq dcl_id (load_dialog "C:\\BricsCAD Scripts\\MACROS\\DIALOGS\\NOTES.dcl"))
  (if (not (new_dialog "NOTES" dcl_id)) (exit))
  (start_list "folderlist")
  (mapcar 'add_list folderList)
  (end_list)
  (action_tile "folderlist" "(NInster (nth (atof $value) folderList))(done_dialog)")
  (start_dialog)
This opens the dialog box with the list of items in the folder, but keep getting this error:
"; error : Automation Error E_INVALIDARG; [IAcadModelSpace] invalid argument for [INSERTBLOCK] method.
The parameter is incorrect."
it prints out the correct file name so I know its doing something right, i just seem to having issues choosing a point to place it into
Edited by Charpzy
Add right before the insert
(princ (strcat "C:\\BricsCAD Scripts\\MACROS\\DWG\\NOTES\\" ent))
And see if the path is right
just tried that, it returns the following path
"C:\BricsCAD Scripts\MACROS\DWG\NOTES\ADDITIONAL TM.dwg"
See if this works.
(defun c:notess (/ Path FolderList dcl_id ent pt MSpace)
  (setq Path "C:\\BricsCAD Scripts\\MACROS\\DWG\\NOTES\\")
  (setq FolderList (vl-directory-files Path "*.dwg" 1))
    (exit)
  (end_list)
  (action_tile "folderlist" "(setq ent (nth (atof $value) folderList))(done_dialog)")
  (start_dialog)
  (setq pt (Getpoint "\nInsertion point")
  (vla-insertblock MSpace pt (strcat Path ent) 1 1 1 0)
worked perfect!
only thing I've just noticed, where I used:
 It shows the items with the extensions for examples 'NOTE.dwg' how could I retrieve the list without the extension
previously I was using   vl-filename-base   along with a foreach loop but not too sure how to implement it into this with the mapcar func
54 minutes ago, mhupp said:
See if this works.
    (exit)
  (end_list)
  (start_dialog)
I have like 500 dwg's as blocks so 2 answers.
Tool palettes I dont use but lots do.
2nd is menu options grouping my blocks yes have made slides, can be scripted to make 100+ in one go. It has the advantage of Next is called automatically when list exceeds 20 items.
Did do a step further make slides and write menu code at same time.
Edited by BIGAL
Im just having an issues grabbing the file name without the extension to list into my dialog, manage to get everything fine just looks a little messy when displaying the .dwg at the end
Use substr remove the last 4 characters will strip the say .dwg
(substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4))
This too:
(vl-filename-base (getvar 'dwgname))
How is this?
Is there a sample?
I.ve tried using them but I'm grabbing the files for the list directly from the folder
how would I implement either of these into this without having to break the list down to make a new list if possible?
50 minutes ago, ronjonp said:
This too:
I've tried looking how to automate making the slides/ make them all in one go because I have a load of items which need slides making to display
Try this:
(mapcar 'add_list (mapcar 'vl-filename-base folderList))
thank you, this worked
1 hour ago, ronjonp said:
Try this:
Re making like 100 slides use a script open dwg, mslide, sldname, close, do next dwg.
You have started another post would be better if you continue here only.
Ask Admin to join.
Asos2000 I just looked at what the mnu code was for a *Icon section, so used the dwg/block names to write the code to a dummy file then cut and pasted into the master mnu. The slides were made using a script based on the same file names.
***icon
**12D
[12D]
[dr_pav_bend]^c^cINSERT dr_pav_bend drag \1;;DRAG
[dr_pav_pipe_con]^c^cINSERT dr_pav_pipe_con DRAG \1;;DRAG
[dr_pav_slot]^c^cINSERT dr_pav_slot DRAG \1;;DRAG
[dr_pav_pit_offset]^c^cINSERT dr_pav_pit_offset DRAG \1;;DRAG
I am trying to find the code, for the last effort just started with a list of block names in a txt file and used that to make a script and make the mnu. The blocks were grouped into common theme so ran like 6 times with different files.
Edited by BIGAL
