I think I'm making a mistake in the foreach line or the list data but I couldn't fix the error. Can someone check?
When i click to mainline it should list all lines and arcs.
I tried LM:ListDifference but it gives error. It didn't fit the working logic.
(defun c:test()
(setq checknum 0)
(setq mylist (ssget '((0 . "LINE"))))
(while (< checknum 1)
  (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex mylist)))
        (setq vla (vlax-ename->vla-object ent)
            start (vlax-curve-getStartPoint vla)
              end (vlax-curve-getendpoint vla))
(setq midarc (ssget "_C" start end '(( 0 . "ARC"))))
(setq sline (ssget "_C" start start '(( 0 . "LINE,ARC"))))
(setq eline (ssget "_C" end end '(( 0 . "LINE,ARC"))))
(setq oldlist (list midarc sline eline))
(setq list1 (sslength mylist))
(setq list2 (sslength oldlist))
(if (/= list1 list2)
(progn (setq mylist (append mylist oldlist)))
(progn (setq checknum 1)))
Example.dwg
Don't know what your trying to do but here are a few things.
  • Your using sslength on a list not a selection set. oldlist is a list of entity names so you need to use length
  • (setq oldlist (list midarc sline eline)) could return nil nil nil making (setq list2 (length oldlist)) would always at least be 3 never 0
  • also (if (/= list1 list2) is just comparing counts not the actual entity's so they could be equal and things wouldn't be added to the selection set.
  •  You probably want to build a point list then use that with ssget but with the fence option. "_F"
This will highlight anything crossing lines you select.
(defun c:test (/ mylist ent vla start end coords SS) ;you should always declare your variables
    (if (not (member start coords))
      (setq coords (cons start coords))
    (if (not (member end coords))
      (setq coords (cons end coords))
  (setq SS (ssget "_F" coords '((0 . "LINE,ARC"))))
  (sssetfirst nil SS)
Hi mhupp,
I solved the problem. I wanted to reply to your comment. 👍
If I reply to your comments in order
  • I agree with your comment, but I was getting the same error even if I used lenght. I gave up on creating lists and combined the 2 ssget selections using the ssadd function.
  • Yes i noticed that.
  • I gave up using this method. Because ssget was not working efficiently when it was nil.
I set up an equation like this
(or (setq midarc (ssget "_C" start end '(( 0 . "ARC"))))(setq x "hello"))
In the next steps I set a condition for the value of x so that I have control of the ssget selections.
  • I couldn't make the choices I wanted with the fence option. When I typed (list end end) instead of coords, it was giving an error because it clicked on the same spot. That's why I didn't use the fence option.
Edited by Scoutr4
