Aljoosha Posted November 16, 2022 Posted November 16, 2022 Hello! I'm a beginner to LISP language and tried to bite off more than I could chew. Found very useful OffHatch LISP from LeeMac named OffHatchV1-01. I can't post .lsp file, so I'll paste whole code here: ;;---------------------=={ Offset Hatch }==-------------------;; ;; ;; ;; Offsets every object in a selection to both sides by a ;; ;; specified distance, then hatches the interior of the ;; ;; closed object formed by the two offset objects. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2012 - www.lee-mac.com ;; ;;------------------------------------------------------------;; (defun c:offhat ( / *error* _reversepoly _substonce _substlast en1 en2 hat inc ob1 ob2 obj sel spc tmp ) (defun *error* ( msg ) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (defun _reversepoly ( enx / _polydata lst wid ) (defun _polydata ( enx ) (if (setq enx (member (assoc 10 enx) enx)) (vl-list* (assoc 10 enx) (assoc 40 enx) (assoc 41 enx) (assoc 42 enx) (_polydata (cdr enx)) ) ) ) (setq wid (cdr (assoc 40 enx)) enx (reverse (_polydata enx)) enx (append (cdddr enx) (list (car enx) (cadr enx) (caddr enx))) ) (while enx (setq lst (vl-list* (cons 42 (- (cdr (assoc 42 enx)))) (cons 41 (cdr (assoc 40 enx))) (cons 40 (cdr (assoc 41 enx))) (assoc 10 enx) lst ) enx (cddddr enx) ) ) (reverse (vl-list* '(42 . 0.0) (cons 41 wid) (cons 40 wid) (cdddr lst))) ) (defun _substonce ( a b l ) (if l (if (equal b (car l)) (cons a (cdr l)) (cons (car l) (_substonce a b (cdr l))) ) ) ) (defun _substlast ( a b l ) (reverse (_substonce a b (reverse l))) ) (cond ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'clayer)))))) (princ "\nCurrent layer locked.") ) ( (progn (initget 6) (and (setq *offset* (cond ( (getdist (strcat "\nSpecify Offset" (if *offset* (strcat " <" (rtos *offset*) ">: ") ": ") ) ) ) ( *offset* ) ) ) (setq sel (LM:ssget "\nSelect LWPolylines: " '("_:L" ((0 . "LWPOLYLINE"))))) ) ) (setq spc (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))) (LM:startundo (LM:acdoc)) (repeat (setq inc (sslength sel)) (setq obj (vlax-ename->vla-object (ssname sel (setq inc (1- inc))))) (if (and (setq ob1 (car (LM:catchapply 'vlax-invoke (list obj 'offset *offset*)))) (setq ob2 (car (LM:catchapply 'vlax-invoke (list obj 'offset (- *offset*))))) ) (if (vlax-curve-isclosed obj) (progn (if (< (vla-get-area ob1) (vla-get-area ob2)) (setq tmp ob1 ob1 ob2 ob2 tmp) ) (setq hat (vla-addhatch spc achatchpatterntypepredefined "ANSI37" :vlax-true achatchobject)) (vlax-invoke hat 'appendouterloop (list ob1)) (vlax-invoke hat 'appendinnerloop (list ob2)) (vla-evaluate hat) ) (progn (setq en1 (entget (vlax-vla-object->ename ob1)) en2 (entget (vlax-vla-object->ename ob2)) ) (entmod (append (_substlast '(42 . 0.0) (assoc 42 (reverse en1)) (vl-remove (assoc 210 en1) (subst (cons 90 (+ (cdr (assoc 90 en1)) (cdr (assoc 90 en2)))) (assoc 90 en1) (subst (cons 70 (logior 1 (cdr (assoc 70 en1)))) (assoc 70 en1) en1 ) ) ) ) (_reversepoly en2) (list (assoc 210 en1)) ) ) (vla-delete ob2) (setq hat (vla-addhatch spc achatchpatterntypepredefined "ANSI37" :vlax-true achatchobject)) (vlax-invoke hat 'appendouterloop (list ob1)) (vla-evaluate hat) ) ) ) ) (LM:endundo (LM:acdoc)) ) ) (princ) ) ;; Catch Apply - Lee Mac ;; Applies a function to a list of parameters and catches any exceptions. (defun LM:catchapply ( fnc prm / rtn ) (if (not (vl-catch-all-error-p (setq rtn (vl-catch-all-apply fnc prm)))) rtn ) ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; ;; Arguments: ;; msg - selection prompt ;; params - list of ssget arguments (defun LM:ssget ( msg params / sel ) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget params)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) ) (vl-load-com) (princ) I want to change offset and hatch color to a certain color code, so it won't be dependent on original PLINE layer properties. Also I would like the offset lines to be extended by offset value on both ends and then connected. Here's a link to image, which helps to understand what I want to modify. https://ibb.co/V2fZKW3 Quote
Aljoosha Posted November 16, 2022 Author Posted November 16, 2022 Forgot to add this - I want linetype to be "Continuous" not "ByLayer". Quote
