I am running AutoCAD 2004 and there is a service packet I need to instal in order to aviod any more internal errors thus leading to a system crash. It tells me to choose one, locked or unlocked, depending on what I have. I follow the directions to find out which is it, but I can't find it
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2881875&linkID=9240617
enter ACADVER on the command line to determine whether you have the locked or the unlocked version of the software.
If the value displayed for the software version has the suffix "s", install the locked service pack. For example, if acadver returns 15.05s, install the locked service pack (note that the version number may vary slightly based on the version of the software).
For all other version values, install the unlocked service pack.
