nicnicman Posted February 18, 2009 Share Posted February 18, 2009 Hello everyone, For some reason I cannot separate these solid objects. I have tried using slice and subtracting out an object. If you look, the objects in the larger grouping are not even touching. This was done with the subtract command. Originally they were touching at two small points like the smaller grouping. Thanks for any suggestions. Nick Drawing1.zip Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 18, 2009 Share Posted February 18, 2009 the objects in the larger grouping are not even touching. F1 Solidedit Separate Quote Link to comment Share on other sites More sharing options...
nicnicman Posted February 18, 2009 Author Share Posted February 18, 2009 Thanks a lot JD Quote Link to comment Share on other sites More sharing options...
