Help please: Create point between 2 points in 3d
barristann
Hi all,
Anyone knows how to modify this code to place a point in between 2 other points in 3D? The below codes belong to PBe and Lee Mac:
(defun c:FOO (/ pt1 pt2 mid)
 (if (and (setq pt1 (getpoint "\n  >>  Specify first point: "))
   (setq pt2 (getpoint "\n  >>  Specify second point: "))
     (prompt "\n<<  The midpoint is: ")
      (reverse (cons (/ (+ (last pt1) (last pt2)) 2) (cdr (reverse (polar pt1 (angle pt1 pt2) (/ (distance pt1 pt2) 2.0))
https://www.cadtutor.net/forum/topic/27359-mid-of-2-points/
  (if (and (setq pt1 (getpoint "\nSpecify first point: ")) (setq pt2 (getpoint "\nSpecify second point: ")))
      (setq mid (mapcar '/ (mapcar '+ pt1 pt2) '(2 2 2)))
      (prompt "\nThe midpoint is: ")
      (princ mid)
-Edit
their is also a snap m2p
Edited by mhupp
Thank you for your help mhupp. It says:
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
See updated code
The midpoint is: (5.84985571613485 4.02541296060991 5.0)
Edited by mhupp
mid is the point
      (princ mid)
      (entmake (list (cons 0 "POINT") (cons 10 mid)))
Edited by mhupp
  • Like 2
