Guest Posted January 1, 2023 Posted January 1, 2023 Hi, Happy New year. I have a slope lisp. Work by picking two points and insert slope text . I change the code to pick a line and insert the slope. I want to add (initget "Line Points") To work for points and Line. It is all the stuff in the code, but I stuck. Can anyone help (defun c:SlopePC (/ p1 p2 a scl ht) (command "_layer" "_m" "Slope" "_c" "140" "" "") (command "style" "TopoCAD" "arial.ttf" 0 "" "" "" "" "") (setq scl (getvar "useri1")) ; <--- Please dont change (setq ht (* 0.00175 scl)) ; <--- Please dont change (setvar "OSMODE" 521) ; (initget "Line Points") ;(if (eq (setq TL-sel ; (getkword (strcat "\nSelect Line or Points[Line/Points]: " "< Line >")) ; ) ; "Points" ; ) ; (if ; (and ; (setq p1 (getpoint "\n1st Point: ")) ; (setq p2 (getpoint "\n2nd Point: ")) ; (setq a (angle p1 p2)) ; ) (setq TL-Line (ssget '((0 . "LINE")))) (setq e (ssname TL-Line 0)) (setq p1 (cdr (assoc 10 (entget e)))) (setq p2 (cdr (assoc 11 (entget e)))) (setq a (angle p1 p2)) (entmake (list '(0 . "TEXT") '(7 . "TopoCAD") '(100 . "AcDbEntity") '(100 . "AcDbText") '(10 0. 0. 0.) (cons 40 ht) (cons 1 (strcat (rtos (abs (* 100 (/ (sin a) (cos a)))) 2 2) " %") ) (cons 50 (if (minusp (cos a)) (+ pi a) a ) ) '(72 . 1) (cons 11 (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.)) p1 p2)) '(73 . 1) ) ) ; ); end if (princ) ) Quote
Steven P Posted January 1, 2023 Posted January 1, 2023 So a quick look, if I take out all the ';', think the error comes to the if statements.... One of them doesn't have a closing ')' - unless I can't count (this is possible) - might be good to label all the closing ')' with what function they are ending, 'if' 'and' 'eq' or whatever As it is the second 'if' statement has 6 statements after, where there should only be 2. Might be you need to enclose some of these with a '(progn' and closing ')' Maybe this is more like it? (defun c:SlopePC (/ p1 p2 a scl ht) (command "_layer" "_m" "Slope" "_c" "140" "" "") (command "style" "TopoCAD" "arial.ttf" 0 "" "" "" "" "") (setq scl (getvar "useri1")) ; <--- Please dont change (setq ht (* 0.00175 scl)) ; <--- Please dont change (setvar "OSMODE" 521) (initget "Line Points") (if (eq (setq TL-sel (getkword (strcat "\nSelect Line or Points[Line/Points]: " "< Line >"))) "Points" ) ; end eq (if (and (setq p1 (getpoint "\n1st Point: ")) (setq p2 (getpoint "\n2nd Point: ")) (setq a (angle p1 p2)) ;; can delete this line or move after the 'if' ;;;ADDED THIS ) ; end and ) ; end if ;;;ADDED THIS (progn (princ "Select Line") (setq TL-Line (ssget '((0 . "LINE")))) (setq e (ssname TL-Line 0)) (setq p1 (cdr (assoc 10 (entget e)))) (setq p2 (cdr (assoc 11 (entget e)))) ;;;ADDED THIS ) ; end progn (setq a (angle p1 p2)) ; as above, can move this line or move after 'if' ;;;ADDED THIS ) ; end if (entmake (list '(0 . "TEXT") '(7 . "TopoCAD") '(100 . "AcDbEntity") '(100 . "AcDbText") '(10 0. 0. 0.) (cons 40 ht) (cons 1 (strcat (rtos (abs (* 100 (/ (sin a) (cos a)))) 2 2) " %") ) ; end cons (cons 50 (if (minusp (cos a)) (+ pi a) a ) ; end if ) '(72 . 1) (cons 11 (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.)) p1 p2)) '(73 . 1) ) ; end list ) ; end entmake ;; ) ; end if ;;DELETE THIS? (princ) ) Quote
Steven P Posted January 1, 2023 Posted January 1, 2023 (edited) Then as a suggestion, (setq TL-Line (ssget '((0 . "LINE")))) (setq e (ssname TL-Line 0)) works but might be better as (setq e (car(entsel "Select Line"))) or use (setq TL-Line (ssget "_+.:E:S" '((0 . "LINE")))) (setq e (ssname TL-Line 0)) to allow single object selection ( http://lee-mac.com/ssget.html ) .. and then (setq e (entget (.... shortens the code a bit later Might then be: (defun c:SlopePC (/ p1 p2 a scl ht) (command "_layer" "_m" "Slope" "_c" "140" "" "") (command "style" "TopoCAD" "arial.ttf" 0 "" "" "" "" "") (setq scl (getvar "useri1")) ; <--- Please dont change (setq ht (* 0.00175 scl)) ; <--- Please dont change (setq os_old (getvar "OSMODE")) (setvar "OSMODE" 521) (initget "Line Points") (if (eq (setq TL-sel (getkword (strcat "\nSelect Line or Points[Line/Points]: " "< Line >"))) "Points" ) ; end eq (if (and (setq p1 (getpoint "\n1st Point: ")) (setq p2 (getpoint "\n2nd Point: ")) ) ; end and (setq a (angle p1 p2)) ) ; end if (progn (princ "Select Line") (setq TL-Line (ssget "_+.:E:S" '((0 . "LINE")))) (setq e (entget (ssname TL-Line 0))) ; can combine this line with the one above if you want (setq p1 (cdr (assoc 10 e))) (setq p2 (cdr (assoc 11 e))) (setq a (angle p1 p2)) ) ; end progn ) ; end if (setvar "OSMODE" os_old) (entmake (list '(0 . "TEXT") '(7 . "TopoCAD") '(100 . "AcDbEntity") '(100 . "AcDbText") '(10 0. 0. 0.) (cons 40 ht) (cons 1 (strcat (rtos (abs (* 100 (/ (sin a) (cos a)))) 2 2) " %") ) ; end cons (cons 50 (if (minusp (cos a)) (+ pi a) a ) ; end if ) '(72 . 1) (cons 11 (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.)) p1 p2)) '(73 . 1) ) ; end list ) ; end entmake (princ) ) also worth putting in an (setq osmode_old (getvar "OSMODE")) before you change it and then you can reset it to what it was when you have finished selecting lines or points Edited January 1, 2023 by Steven P Quote
Guest Posted January 1, 2023 Posted January 1, 2023 Hi Steven P.I have this message ; error: syntax error Quote
devitg Posted January 1, 2023 Posted January 1, 2023 44 minutes ago, prodromosm said: Hi Steven P.I have this message ; error: syntax error As to test , please upload your sample dwg. or state the (getvar "useri1") (getvar "useri1") Quote
Guest Posted January 1, 2023 Posted January 1, 2023 ( DEFUN C:SETSC () (setvar "OSMODE" 13) (SETQ CURSC (getvar "useri1" )) (princ "Set scale 1:")(princ cursc) (setq newsc (getint "\nNew scale 1:")) (setvar "useri1" newsc) (setq a1 (getvar "useri1")) (princ "\n The scale is 1:")(princ newsc)(princ) ) Quote
Steven P Posted January 1, 2023 Posted January 1, 2023 1 hour ago, prodromosm said: Hi Steven P.I have this message ; error: syntax error It should be corrected now Quote
devitg Posted January 1, 2023 Posted January 1, 2023 16 minutes ago, Steven P said: It should be corrected now @Steven P, please show the correction done to your lisp. Quote
Guest Posted January 1, 2023 Posted January 1, 2023 (defun c:SlopePC (/ p1 p2 a scl ht) (command "_layer" "_m" "Slope" "_c" "140" "" "") (command "style" "TopoCAD" "arial.ttf" 0 "" "" "" "" "") (setq scl (getvar "useri1")) ; <--- Please dont change (setq ht (* 0.00175 scl)) ; <--- Please dont change (setq os_old (getvar "OSMODE")) (setvar "OSMODE" 521) (initget "Line Points") (if (eq (setq TL-sel (getkword (strcat "\nSelect Line or Points[Line/Points]: " "< Line >"))) "Points" ) ; end eq (if (and (setq p1 (getpoint "\n1st Point: ")) (setq p2 (getpoint "\n2nd Point: ")) ) ; end and (setq a (angle p1 p2)) ) ; end if (progn (princ "Select Line") (setq TL-Line (ssget "_+.:E:S" '((0 . "LINE")))) (setq e (entget (ssname TL-Line 0))) ; can combine this line with the one above if you want (setq p1 (cdr (assoc 10 e))) (setq p2 (cdr (assoc 11 e))) (setq a (angle p1 p2)) ) ; end progn ) ; end if (setvar "OSMODE" os_old) (entmake (list '(0 . "TEXT") '(7 . "TopoCAD") '(100 . "AcDbEntity") '(100 . "AcDbText") '(10 0. 0. 0.) (cons 40 ht) (cons 1 (strcat (rtos (abs (* 100 (/ (sin a) (cos a)))) 2 2) " %") ) ; end cons (cons 50 (if (minusp (cos a)) (+ pi a) a ) ; end if ) '(72 . 1) (cons 11 (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.)) p1 p2)) '(73 . 1) ) ; end list ) ; end entmake (princ) ) Quote
Steven P Posted January 1, 2023 Posted January 1, 2023 54 minutes ago, devitg said: @Steven P, please show the correction done to your lisp. It was the second (setq a (angle p1 p2)) in the wrong place, Corrected to be: (progn (princ "Select Line") (setq TL-Line (ssget "_+.:E:S" '((0 . "LINE")))) (setq e (entget (ssname TL-Line 0))) ; can combine this line with the one above if you want (setq p1 (cdr (assoc 10 e))) (setq p2 (cdr (assoc 11 e))) (setq a (angle p1 p2)) ) ; end progn Quote
BIGAL Posted January 1, 2023 Posted January 1, 2023 (edited) (setq scl (getvar "useri1")) ; <--- Please dont change Rather than above use (if (= (vlax-ldata-get "Prodromosm" "scl") nil) (progn (setq scl (getreal "\nEnter scale ")) (vlax-ldata-put "Prodromosm" "scl" scl) ) ) User1 can be changed by other programs. Edited January 1, 2023 by BIGAL Quote
