error: ActiveX Server returned the error: unknown name: "ADDDIMARC"?
Hi, I don't have much knowledge about lisp, I need help members. Thanks.
AddDimArc Method:
RetVal = object.AddDimArc(ArcCenter, FirstEndPoint, SecondEndPoint, ArcPoint)
I test it:
(defun c:test()
(vl-load-com)
(setq arc (car (entsel)))
(setq arcobj (vlax-ename->vla-object arc))
(setq sp (vlax-curve-getstartpoint arcobj))
(setq ep (vlax-curve-getendpoint arcobj))
(setq cpt (vlax-get arcobj 'Center))
(setq p3 (getpoint cpt))
(vlax-invoke arcobj 'AddDimArc cpt sp ep p3)
);end
What is error: ActiveX Server returned the error: unknown name: "ADDDIMARC"?
Edited by SLW210
Added Code Tags!
You need to tell AutoCAD where to "add" the dim.
(defun c:test(/ thisdrwing mspace arc acrobj sp ep cpt p3)
  (vl-load-com)
  (setq thisdrawing (vla-get-activedocument (vlax-get-acad-object)))
  (setq mspace (vla-get-modelspace thisdrawing))
  (vla-adddimarc mspace cpt sp ep p3)
https://www.afralisp.net/archive/methods/listb/adddimaligned_method.htm
Edited by mhupp
  • 9 months later...
  (vl-load-com)
Thank you for hepl me!
You can check the available properties & methods for any given ActiveX object using the vlax-dump-object function, for which I have provided a utility program here.
2 suggestions
(setq arc (car (entsel "\nPick an Arc ")))
(setq p3 (getpoint cpt "\nPick new dim point for arc "))
