Hi all,
actually some time i forgot to change Defpoints layer to it's desire layer, result is that object are not print as the object is in Defpoints layers, is this possible whenever i open my autocad Defpoints layer color will be in different color instead of white
Don't know what exactly what you want. This will make a Defpoint layer or if existing properties will be changed to color white, thawed, and plotting turned off.
(defun C:start ()
  (entmake '((0 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "Defpoints") (70 . 0) (62 . 7) (290 . 0)))
(C:Start)
Defpoints is a layer that you should never draw on, so fix what is causing objects to be drawn on that layer.
I just found the below code in a folder and changed it to "defpoints".
There are so many improvements to this code that can be made, but hopefully it can get you started...
;;;moves all objects from layer defpoints and places them on a new layer called "from_Def"
(defun c:from0 ()
   (setq ssl0 (ssget "x" '((8 . "0"))))
   (COMMAND "-layer" "N" "from_Def" "")
   (COMMAND "chprop" ssl0 "" "la" "from_Def" "")
Actually my problem is i have some other object which should be in defpoints layers and i want whenever open autocad defpoints color default change from white to red or any other color
Keeping it simple, run this to change Defpoints layer colour to Green (use number 1 for red), should highlight what objects are on that layer
(command "-layer" "c" 3 "Defpoints" "")
Using similar and a wildcard for the layer names you can also turn off all layers, and then turn on defpoints layer to move objects on that layer only if you want
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-turn-on-all-layers/td-p/6671292
it is also possible to select all objects using a selection set and filtering it for the later defpoints to do the same
what i understand it will be run every time and in every dwg, but is it possible to do once and it will automatically change the color whenever open any dwg or lisp will run at the startup when dwg will open
Edited by pmadhwal7
