check block has layers including nested blocks.
Hi I tired to change block's layer to 0 if it has more than 2 layers (except layer 0, defpoints ) inside and also nested blocks.
So I made a lisp and but it doesn't including nested blocks. please help
ex)
1. block 1 has  block2, block3 and many layers entities (circle, lines...)
  -> block 1 layer to 0
2. block 2 has block 4 (layer A) and block 5 (layer B).
  -> block 2 layer to 0
3. block 3 has 1 layer entities.
  -> nil
<LISP>
(defun c:test ( / ss ent tblist ename llist blist )
  (setq ss (ssget "_All" '((0 . "INSERT"))))
  (setq i (sslength ss))
    (setq ent (ssname ss (setq i (- i 1))))
    (if (= (cdr (assoc 0 (entget ent))) "INSERT")
        (setq tblist (tblsearch "BLOCK" (cdr (assoc 2 (entget ent)))))
        (setq ename (cdr (assoc -2 tblist)))
        (while ename
          (if llist
            (setq llist (append (list (cdr (assoc 8 (entget ename)))) llist))
            (setq llist (list (cdr (assoc 8 (entget ename)))))
          (if (= "INSERT" (cdr (assoc 0 (entget ename))))
              (setq blist (append (list (cdr (assoc -1 (entget ename)))) blist))
              (setq blist (list (cdr (assoc -1 (entget ename)))))
          (princ (cdr (assoc 0 (entget ename))))
          ;(princ (car blist))
          (vla-put-layer (vlax-ename->vla-object (car blist)) "0")
          (setq ename (entnext ename))
        (setq llist (vl-remove "0" llist))
        (if (<= 2 (length llist))
            (vla-put-layer (vlax-ename->vla-object ent) "0")
This uses the block definition to update the blocks in the drawing.
(defun C:FOO (/ blk Drawing blkname ent x)
  (vl-load-com)
  (vlax-for blk (vla-get-blocks (setq Drawing (vla-get-activedocument (vlax-get-acad-object))))
    (if (and (= (vla-get-isxref blk) :VLAX-FALSE)
             (not (wcmatch (vla-get-name blk) "*`**,*|*"))
        (setq blkname (vla-get-name blk))
        (setq ent (tblobjname "BLOCK" blkname))
        (while (setq ent (entnext ent))
          (if (/= (cdr (assoc 8 (setq x (entget ent)))) "0")
            (entmod (subst (cons 8 "0") (assoc 8 x) x))
  (vla-Regen Drawing)
