Waheed Posted February 4, 2023 Posted February 4, 2023 i am using this lisp but on display bar shown sq inch in required sq feet instead of inch regards ------------------------------------------------------------------------------------------------------------------------------------------ ;| ;; TotalADD Total Addition v. 1.0 ;; By: Andrea Andreetti © 2009-10-20 ;; |; ;; (princ "\nTotalADDition v.1.0 activated! -run \"TADD\" to start or \"TADD-r\" to end." ) (defun c:tadd (/ itemarea itemperimeter itemlinelength itemarclength itemsplinelength itemregionperimeter itemcircumference itemsplineperimeter itemplineperimeter itemplinelength itemtracelength itemarclength itemellipselength a b c d p1 p2 itemlength tarea tperim tlength ) (vl-load-com) (defun *oo_object_modification* (objreactor objectsmodified) (setq selected_objects (vla-get-pickfirstselectionset (vla-get-activedocument (vlax-get-acad-object)) ) ) (setq itemarea 0 itemperimeter 0 itemlinelength 0 itemarclength 0 itemsplinelength 0 itemregionperimeter 0 itemcircumference 0 itemsplineperimeter 0 itemplineperimeter 0 itemplinelength 0 itemtracelength 0 itemarclength 0 itemellipselength 0 ) ;AREA (vlax-for n selected_objects (if (vlax-property-available-p n 'area) (if (eq (vla-get-objectname n) "AcDbRegion") (setq itemarea (+ itemarea (vla-get-area n))) (if (vlax-curve-isclosed n) (setq itemarea (+ itemarea (vla-get-area n))) ) ) ) ;;CIRCLE (if (vlax-property-available-p n 'circumference) (setq itemcircumference (+ itemcircumference (vla-get-circumference n))) ) ;;SPLINE (if (eq (vla-get-objectname n) "AcDbSpline") (if (vlax-curve-isclosed n) (setq itemsplineperimeter (+ itemsplineperimeter (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) (setq itemsplinelength (+ itemsplinelength (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) ) ) ;;REGION (if (eq (vla-get-objectname n) "AcDbRegion") (setq itemregionperimeter (+ itemregionperimeter (vla-get-perimeter n))) ) ;;PLINE (if (or (eq (vla-get-objectname n) "AcDb2dPolyline") (eq (vla-get-objectname n) "AcDbPolyline") ) (if (vlax-curve-isclosed n) (setq itemplineperimeter (+ itemplineperimeter (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) (setq itemplinelength (+ itemplinelength (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) ) ) ;;LINE (if (eq (vla-get-objectname n) "AcDbLine") (setq itemlinelength (+ itemlinelength (vla-get-length n))) ) ;;ARC (if (eq (vla-get-objectname n) "AcDbArc") (setq itemarclength (+ itemarclength (vla-get-arclength n))) ) (if (eq (vla-get-objectname n) "AcDbEllipse") (setq itemellipselength (+ itemellipselength (vlax-curve-getdistatparam n (vlax-curve-getendparam n)) ) ) ) ;;TRACE (if (eq (vla-get-objectname n) "AcDbTrace") (progn (setq plist (vlax-safearray->list (vlax-variant-value (vla-get-coordinates n)) ) ) (setq a (list (nth 0 plist) (nth 1 plist) (nth 2 plist))) (setq b (list (nth 3 plist) (nth 4 plist) (nth 5 plist))) (setq c (list (nth 6 plist) (nth 7 plist) (nth 8 plist))) (setq d (list (nth 9 plist) (nth 10 plist) (nth 11 plist))) (setq p1 (polar a (angle a b) (/ (distance a b) 2.0))) (setq p2 (polar c (angle c d) (/ (distance c d) 2.0))) (setq itemtracelength (+ itemtracelength (distance p1 p2))) ) ) ) ;;_end vlax-for (setq itemperimeter (+ itemcircumference itemsplineperimeter itemregionperimeter itemplineperimeter ) ) (setq itemlength (+ itemplinelength itemsplinelength itemlinelength itemtracelength itemarclength itemellipselength) ) (setq tarea (rtos itemarea 2 8)) (setq tperim (rtos itemperimeter 2 8)) (setq tlength (rtos itemlength 2 8)) (acet-ui-status (strcat "Toatl Area: " tarea "\n" "Total Perimeter: " tperim "\n" "Total Length: " tlength) ) ) ;;OBJECT SELECTION (if oo_object_modification (progn (vlr-remove oo_object_modification) (setq oo_object_modification nil) ) ) (setq oo_object_modification (vlr-miscellaneous-reactor nil '((:vlr-pickfirstmodified . *oo_object_modification*)) ) ) ;;Command ended (if oo_object_modification_action (progn (vlr-remove oo_object_modification_action) (setq oo_object_modification_action nil) ) ) (setq oo_object_modification_action (vlr-command-reactor nil '((:vlr-commandended . *oo_object_modification*) ;(:vlr-commandcancelled . *oo_object_modification_CANCEL*)) ) ) ) ) (defun c:TADD-r () (if oo_object_modification_action (progn (vlr-remove oo_object_modification_action) (setq oo_object_modification_action nil) ) ) (if oo_object_modification (progn (vlr-remove oo_object_modification) (setq oo_object_modification nil) ) ) ) TADD.LSP Quote
marko_ribar Posted February 4, 2023 Posted February 4, 2023 Maybe, studying this can help : https://www.theswamp.org/Sources/doc/avlisp/#rtos Quote
