Irishpotato Posted February 22, 2023 Posted February 22, 2023 I am trying to subtract a pre determined layer list from my current drawing layers and have the results export to a txt file. I was able to write part of the lisp myself and I found a lisp online for writing to a text file however I think that is my issue. Below is what i have so far. Thank you in advance for your help. (DEFUN C:testing () (setvar "cmdecho" 1) (vl-load-com) (vlax-for lyr (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))(setq then (cons (vla-get-name lyr) table))) ;retrieve layers in current file (setq now '(BERM BORDER CABLE LINE)) ;preassigned layers to look for (defun ListsDifference ( now then )(if l1(if (vl-some '(lambda ( l ) (member (car now) l)) then)(ListsDifference (cdr now) ls)(cons (car l1) (ListsDifference (cdr now) then))))) ;subtract layers in active file from preassigned list (setq ;attempting to create txt file from of the list differences lyrent (tblnext LListDifference t) dprefx (getvar "dwgprefix") dname1 (getvar "dwgname") dname2 (substr dname1 1 (- (strlen dname1) 4)) ;remove old extension filename (strcat dname2 ".txt") ;add new extension padding " " header1 (substr (strcat "LAYER" padding) 1 30) header (strcat header1) prmpt (strcat dprefx filename) file (open prmpt "a") ) (write-line filename file) (write-line "" file) (write-line header file) (write-line "" file) (while lyrent (setq lyrname (substr (strcat (strcase (cdr (assoc 2 lyrent))) padding) 1 30) lyrdata (strcat lyrname) ) (write-line lyrdata file) (setq lyrent (tblnext LListDifference)) ) (close file) (prompt (strcat "\nCreated " prmpt)) (princ) ) Quote
Emmanuel Delay Posted February 24, 2023 Posted February 24, 2023 Can you repeat what end result you want? You want the current layer list; except skip the layers "BERM", "BORDER", "CABLE", "LINE" Then export that list, right? So just the layer names? Quote
