macro to 1st set layer to REV before creating revision cloud, then return to previous active layer
Fist off, I realize this can be done with the tool palette. For my personal education on learning Diesel, I want to figure out the code to do this with a macro.
Assuming the layers already exist, the following works flawlessly with the dimlinear command:
^C^C-layer;set;DIMENSION; _DIMLINEAR;\\\LAYERP
However, the behavior is inconsistent when the revision cloud command is substituted. While testing in various drawings, once in a while it returns to the previous layer, but most of the time the REV layer stays active:
^C^C-layer;set;REV; _^Rrevcloud \\\layerp
I've tested with various combinations of a "space" and/or semi-colon after the revcloud command, but nothing seems to make the macro work as intended. I'm sure there is some sort of Diesel syntax thing going on. Any suggestions?
In AutoCAD LT, type CUI and review the standard revision cloud command. The "_R" prefix is there, though I'm not yet familiar enough with the command syntax to understand what the prefix designates.
Either way, with or without the "_R" prefix, the macro DOES set the layer to REV and execute the revcloud, but does NOT return to the previous active layer. It seems there is something in AutoCAD's processing of the revcloud command that causes the macro to exit after the command, ignoring the \\\layerp function.
