Maybe something along these lines:
;; ZoomText © Lee Mac 2011
(defun c:ZoomText ( / ss ac l p1 p2 x ) (vl-load-com)
 (if
   (ssget "_X"
     (list (cons 0 "TEXT,MTEXT")
       (cons 1
         (strcat "*"
           (vl-list->string
             (apply 'append
               (mapcar
                 (function
                   (lambda ( c )
                     (if (vl-position c '(35 64 46 42 63 126 91 123 44 96))
                       (list 96 c)
                       (list c)
                 (vl-string->list
                   (getstring t "\nSpecify Text to Search for <All> : ")
     (vlax-for o
       (setq ss
         (vla-get-ActiveSelectionSet
           (vla-get-ActiveDocument
             (setq ac (vlax-get-acad-object))
       (setq l
         (cons
           (cons o
             (mapcar 'vlax-safearray->list
                 (vla-getBoundingBox o 'p1 'p2) (list p1 p2)
           l
     (vla-delete ss)
     (while (setq x (car l))
       (vla-ZoomCenter ac (vlax-3D-point (apply 'mapcar (cons '(lambda ( a b ) (/ (+ a b) 2.)) (cdr x)))) 1.0)
       (vla-ZoomScaled ac [b][color=red]0.01[/color][/b] acZoomScaledRelativePSpace)
       (initget "Next Exit")
       (setq l
         (if (eq "Exit" (getkword "\nZoom to Next Object? [Next/Exit] <Next> : ")) nil (cdr l))
   (princ "\n** None Found **")
I'm not sure whether the figure marked in red needs to be 0.01 or 100.0 however...
  • Replies 23
  • Lee Mac
    9
  • dchilders
    7
  • lfe011969
    3
  • svorgodne
    2
Awesome, I can't thank you enough. What a time saver:D
You're very welcome :)
  • 6 years later...
Hi, is this possible to add other items, like ATTRIBUTES, MLEADERS etc... to the search ?
