Select image by click inside - help with modification of existing lisp
This small lisp that I found on this forum and adapted a little (it was meant for groups), selects an image by clicking anywhere inside it. After clicking one image, it highlights it and exits the command. It would be helpful to modify it so that I can click more images one by one and continue to add them to the selection set until I press enter. In other words, I want it to repeat the selection procedure till I selected all wanted images. Can anybody help with that? Thanks in advance.
(defun c:CIMG (/ ops enl pts sel)
  (and (setq enl (entlast))
       (setvar 'cmdecho 0)
       (princ "\nClick inside the image: ")
       (vl-cmdf "_.BOUNDARY" pause "")
       (not (equal enl (setq enl (entlast))))
       (setq pts (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) (entget enl))))
       (vl-cmdf "_.ERASE" enl "")
       (setvar 'cmdecho 1)
       (setq sel (ssget "_CP" pts '((0 . "IMAGE"))))
       (sssetfirst nil sel))
(if (= sel nil)
(princ "
You did not click an image!"))
(princ))
CIMG.lsp
Perhaps this?
(defun c:CIMG ( / e_last ss pt_in pts sel)
  (setq e_last (entlast) ss (ssadd))
  (while (setq pt_in (getpoint "\nClick inside the image <Right click or Enter to exit>: "))
    (bpoly pt_in nil '(0 0 1))
    (cond
      ((and (entlast) (not (eq e_last (entlast))))
        (setq pts (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) (entget (entlast)))))
        (entdel (entlast))
        (if sel
          (ssadd (ssname sel 0) ss)
          (princ "\nYou did not click an image!")
  (if ss (sssetfirst nil ss))
  (prin1)
56 minutes ago, Tsuky said:
Perhaps this?
    (cond
        (entdel (entlast))
        (if sel
  (prin1)
It's not working, see below:
Command: cimg
error: null function: BPOLY
LATER EDIT: But it works like this:
(command "_bpoly" pt_in "") instead of (bpoly pt_in nil '(0 0 1))
Forgot to say that I am using Progecad so maybe that is the reason. Thank you so much!
Edited by Radu Iordache
Select images ???
(setq sel (ssget '((0 . "IMAGE"))))
@Radu Iordache
You have problems with adjacent images, so try like this...
(defun c:CIMG ( / e_last ss pt_in pts dlt p1 p2 sel)
    ;(bpoly pt_in nil '(0 0 1))
    (command "_bpoly" "_none" pt_in "")
    (cond
        (setq
          dlt (/ (- (caar pts) (caadr pts)) 1000.0)
          p1 (list (- (apply 'min (mapcar 'car pts)) dlt) (- (apply 'min (mapcar 'cadr pts)) dlt))
          p2 (list (+ (apply 'max (mapcar 'car pts)) dlt) (+ (apply 'max (mapcar 'cadr pts)) dlt))
        (entdel (entlast))
        (setq sel (ssget "_W" p1 p2 '((0 . "IMAGE"))))
        (if sel
          (progn (ssadd (ssname sel 0) ss) (sssetfirst nil ss))
  (prin1)
Edited by Tsuky
16 hours ago, Tsuky said:
@Radu Iordache
    (cond
        (setq
        (entdel (entlast))
        (if sel
  (prin1)
It works! Thank you very much for your time! I also made this version involving some offset to the original boundary and using that with WP method but it may not work in some cases.
(setq snap (getvar "osmode"))
(setvar "osmode" 0)
(setq imag (ssget "X" '((0 . "IMAGE"))))
  (while (setq pt_in (getpoint "\nClick in imagine <Sau click dreapta/enter pentru a termina selectia>: "))
    (vl-cmdf "_.BPOLY" "a" "b" "n" imag "" "x" pt_in "")
    (command "-offset" "100" "(entlast)" "0,0" "")
    (cond
        (entdel (entlast))
        (entdel (entlast))
        (setq sel (ssget "WP" pts '((0 . "IMAGE"))))
        (if sel
            (setq nents (sslength sel))
            (repeat nents
              (setq ent (ssname sel (setq nents (1- nents))))
              (ssadd ent ss)
(setvar "grips" 0)
(sssetfirst nil ss)
  (setvar "grips" 1)
  (setvar "osmode" snap)
  (if (not sel)
    (princ "\nNu s-a selectat nicio imagine."))
  (prin1)
On 4/19/2023 at 8:44 AM, BIGAL said:
Select images ???
I wanted to be able to select images (one or more but not all ) by clicking inside them (and not their frame).
