3dwannab Posted April 19, 2023 Posted April 19, 2023 I have this lisp which saves out to 3 different file types. I edit the dwt and then it saves out to each. I want the dwt to have a description like below but this line sometimes gets stuck at the "Y" command. ; What this does ; Saves the dwt file out to a dwg and Standards file ; Written on 2023.02.10 by 3dwannab ; Issues: ; The save as template sometimes doesn't work. Is there a vla method to do this? (defun c:Save_DWT_to_Templates (/) (setvar "FILEDIA" 0) (c:PQ) ;; Purge the drawing before saving (command "_SAVEAS" "LT2018" "" "Y") (command "_SAVEAS" "Standards" "" "Y") (setvar "FILEDIA" 1) (command "_.close" "_Y") ; (command "_SAVEAS" "Template" "" "Y" "M" "Company name here (Compatible with Sheet Sets)") ) ; (c:Save_DWT_to_Templates) Quote
Steven P Posted April 19, 2023 Posted April 19, 2023 VLA Save as (vla-SaveAs (vla-get-ActiveDocument (vlax-get-acad-object)) (strcat (getvar "dwgprefix") "dwgname" ".dwg") version) where version is the version code such as "ac2018_dwg" - you can get this by opening the DWG with a text editor (notepad) and the first word is this and depends on the version it is saved as Getting stuck on 'Y' if the drawing exists? (if (= 1 (getvar "dwgtitled")) ;;if existing drawing (progn ;;Stuff if exiting draswing ) ; end progn (progn ;;Stuff if new drawing ) ; end progn ) ; end if Quote
Steven P Posted April 19, 2023 Posted April 19, 2023 Might be better for you as well - resets system variables to what they were (in case filedia started at something other than 1 ) (setq vars '("CMDECHO" "FILEDIA")) ;;3 lines to disable command promts and echo (setq old (mapcar 'getvar vars)) ;; save what the system variables above are (mapcar 'setvar vars '(0 0)) ;; Set above system variables to 0 (or whatever) --- CODE --- (mapcar 'setvar vars old) ;;reset system variables Quote
3dwannab Posted April 20, 2023 Author Posted April 20, 2023 (edited) Thanks, how would I save it to a DWT file with a description using the vla method and set it to metric? When I open the DWT file in notepad the version is AC1032. Edited April 20, 2023 by 3dwannab Quote
Steven P Posted April 20, 2023 Posted April 20, 2023 Try this link: https://help.autodesk.com/view/OARX/2023/DEU/?guid=GUID-ED0D0B02-25FC-4ED2-9DEE-2B0C9AA9416A Though to be honest I don't often make template files so don't have a LISP for it - try it and see what happens Quote
